A bedtime story with a happy ending
Scott711
Scott711's Avatar
A bedtime story with a happy ending - 02.01.2006, 12:37 AM
:dft009:
Well, after a couple of months of saving and spending I finally got everything put together and made my first run with the new set up, but first a little history. I came to this forum a couple months ago because I was not happy with my HV-Maxx system and wanted more. After lurking around and reading numerous threads it became oblivious that people here had a lot to offer in terms of how to set up a killer truck. So I joined and began with the questions and got great advice from many people and I thank all who helped and continue to help. My new additions include the following:
BK9920
Warrior 8XL
UBEC
Dimension Engineering LVC (thanks metalman this thing works great)
Strobe slipper clutch
Mod 1 spur & pinion 14/51 for now will be trying a 16 soon.
Lipos 5s 3700Mah will be experimenting with different brands and sizes.
All this was assembled to what I already had:
Torpedo chassis
UE 8 spyders and racer x suspension
MIP bones
And much more
After spending countless hours trying to decide how and where I wanted to mount the lipos I came up with a cross chassis design (see photos), which seems to give good balance to the truck.
As anyone who’s made wholesale changes like this knows there can be a tense moment or two when you finally get ready to make the first run, i.e. did everything get soldered in the right order and are all the parts installed correctly. So I plugged in the battery, got my programming beeps and replaced the jumper. Now I’m ready to put rubber to the pavement but I live in Seattle and it’s been raining non-stop forever it seems. Finally I get a half-day and things dry out enough to see what the new setup can do. I’m happy to report that I had a successful test run, great acceleration and the top speed was scary. I didn’t push it to hard since it was the maiden voyage and I was running topless:dft002: . Battery temps were a very cool 75° but motor and esc were a little higher than I would like 120° - 125° especially considering I was running topples :dft002: and the air temp was about 40°. Question, will taller gearing bring up the battery temps and lower the motor esc temp? What is an unhealthy temp for motor and esc? Thanks for enduring my story, I just felt a need to share my experience and thank everyone. BTW I got about 20 minutes runtime, so I’m pretty happy with that.
http://photobucket.com/albums/a156/scott711/
