Traxxas center diff in top speed calculator?
e-mikey
Traxxas center diff in top speed calculator? - 07.24.2009, 08:02 AM
I put a traxxas center diff in my revo, what should I select from the drop down menu for the transmission?
I tried 1/1 but I don't think my top speed is 80+ mph.
Thanks
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.24.2009, 08:43 AM
Does the transmission ratio change with installation of a center diff?
brushlessboy16
brushlessboy16's Avatar
07.24.2009, 09:21 AM
nope.
Use the stock transmission ratio.
nitrostarter
nitrostarter's Avatar
07.24.2009, 10:07 AM
The Traxxas center diff simply replaces the bottom gear of the tranny. Why would the ratio change?
Only way possible is to remove the tranny and use a Center Diff from a buggy or truggy with a custom mount.
N. Rustler conversion
07.24.2009, 10:16 AM
nope.
True, using a CD or the stock setup doesn't change the ratio. The only thing that does change the tranny is whether you have the narrow, standard, or wide ratio gearsets. And those simply adjust the gears on the input and idler shafts.
