new to lipos
maxxbear
new to lipos - 09.29.2009, 06:26 PM
hi guys,quick question,want to run 4s/5s on my flm max w/mmm what would be a good starting point for spur/pinion truck already has all upgrades,and getting rid of my hv novak.looking at hyperion g3s.would there be any other batts. in their league.i mostly bash in street/parking lots.thanks
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.29.2009, 06:52 PM
Here ya go MaxxBear, This little tool (Thanks to BrianG) can help you figure out your questions.
http://scriptasylum.com/rc_speed/_top_speed.html
use the top speed calc to figure out the gearing, don't over gear or you'll run into problems.
redshift
RC-Monster Square Tube
redshift's Avatar
09.29.2009, 07:24 PM
"looking at hyperion g3s.would there be any other batts. in their league"
Yes, but the Hyperions seem to be the #1 bang-for-buck at the moment, the only issue you may have is they will do serious damage to lesser drivetrains. You can't go wrong with Hyperion, they really deliver!
maxxbear
09.29.2009, 07:28 PM
do you guys think their would be much of a balance problem using just i pack versus 2(1-14.8 or 2-7.4)thanks
redshift
redshift's Avatar
09.29.2009, 10:52 PM
From what I understand using one 2S and one 3S is fine as long as the individual cells are identical, and have the same use, if not new.
09.29.2009, 11:38 PM
For balance on the maxx 2 packs are preferable. You can run a pair of 2s packs for 4s, or a 2s and a 3s for 5s total. Best to keep the same packs together, as all of the cells will age at the same rate if always run together. I would go with 5s, 4s setups tend to have high current draws, and 5s will allow for lower gearing (for the same speed if using the same motor) and you will get longer runtime.
maxxbear
09.30.2009, 10:30 AM
thanks for info guys
