Spun a wheel hex inside the wheel....
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
Spun a wheel hex inside the wheel.... - 10.09.2009, 08:43 PM
It is COMPLETELY round haha, whups. I am wondering if copious amounts of JB weld will hold it, before I waste JB weld? Or is it time for new wheels? Anyone have any cool recommendations for a MT size wheel? Still has to be tough enough to take some HARSH abuse. I am thinking maybe solid black dished wheels.Thanks guys,
-Matt
10.09.2009, 09:13 PM
What size hex, and plastic or metal (hex)?
I would say either jbweld or epoxy resin should do the trick , only issue being you have to make sure the hex is centered as to avoid wheel wobble. You will have to glue the hex to the wheel permanently though- might want to add some star-like fingers to the round hole before adding the glue though, so that the glue & hex 'plug' doesnt spin out the hole - like a loose pinion spins on a round shaft- a splined pinion and shaft doesnt have that problem.
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
10.09.2009, 09:55 PM
14mm alum. hex. I think the smaller hex is part of the problem, standard savage hex's are 17mm right? I am using the smaller ones that came with it. I may just pick up solid dish wheels with 17mm hex's...Hmmm.
10.09.2009, 10:11 PM
17mm is pretty standard for the savy range yeah, not sure why they went with 14mm hexes for the FLUX considering BL has vastly more torque than nitro- no foresight
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
10.09.2009, 10:19 PM
No no, the savage came with an optional 14mm wheel hex, so i picked up some HPI wheels with a 14mm hex. It has 17mm wheel hex's from the factory.
