Which lipos for 9xl & 9920? Please help. 10c?15c?20c?
4u2nv
Which lipos for 9xl & 9920? Please help. 10c?15c?20c? - 02.22.2006, 01:51 PM
I have a Gmaxx I've been building and I'm in need of some advice. I have a 9920 esc with a 9xl motor. I have the single speed conversion on my maxx. My question is what can I run for Lipos? There are so many options. My biggest question is can I run 10c or 15c or do I need 20c batteries. I know I want to use 11.1v 3s 4000 mah packs but I don't know what the difference is between the 10c,15c or 20c versions of them. I know price is a big difference. Could someone please help. Thanks Guys.
Serum
Serum's Avatar
02.22.2006, 02:08 PM
i would take the 20C things, the XL motors can draw serious amps.
that 80A the 20C 4000mAh packs can deliver is just enough.
Superemaxx89
02.22.2006, 02:15 PM
I would go 6s for a 9xl
Serum
Serum's Avatar
02.22.2006, 02:30 PM
I assumed he ment 2 11.1V packs in serie.. :D (the way it's meant to be.. )
4u2nv
02.22.2006, 04:35 PM
So no less than 20c then correct? And I did mean I was going to use two 3s packs together sorry for the confusion? Any idea where to get the best deals on packs like these?
coolhandcountry
coolhandcountry's Avatar
02.22.2006, 06:37 PM
I think this mean he is going to run 6s lipo rene. Which should work great on the 9xl motor.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
02.22.2006, 04:40 PM
I would use a minimum of 4S or 5S with this motor, otherwise the motor will take very much current from your packs and run not as efficient as you would like.
4u2nv
02.22.2006, 05:38 PM
Would these batteries be ok?
http://cgi.ebay.com/11-1V-4000Lithiu...QQcmdZViewItem
4u2nv
02.22.2006, 08:49 PM
OK, I'm going to clear up my question. I'm asking if I can use the batteries above with a 9920 esc and a 9xl motor. I will be using 2 - 11.1v 3s packs which should make 1 - 6s pack if I'm correct. So It should make a 11.1v 6s 4000mah 15c. Will this be good? What can I expect for speeds?
MetalMan
MetalMan's Avatar
02.22.2006, 10:17 PM
NO!! If you look at the auction, it says this pack has 18ga. wire... That's WAY too thin. Even if the wire was thicker, I would not trust these "new Chinese cells"... Go for something with a reputation, like Hyperion, Polyquest, or LiMn.
20C is unnecessary IMO. If you get a pack that can handle about 45amps continuous with 80amps burst then that should be adequate. A 6000mah 8C pack is rated to deliver 48amps continuously (for example), and would give better runtime than a 4000mah pack. Unless you are extremely worried about weight, I wouldn't even get a 20C pack. You pay a lot extra for them, and 10C-15C packs are plenty...
squeeforever
squeeforever's Avatar
02.22.2006, 05:41 PM
i think those would be fine.
Serum
Serum's Avatar
02.22.2006, 05:53 PM
Not in 3S with a 9XL, or are you planning on running 25-30 mph?
kmracer66
kmracer66's Avatar
nice new graphic there serum.
FT18T - stock
REVO - P2's, Red Rods, 40wt, Green/Tan, MX3. one day, it will be brushless. :028:
coolhandcountry
02.22.2006, 08:54 PM
6s is 22.2volts. It should be fine with the batteries. I think I would go with the 20c rated batteries for a little extra insurance.
Peace!
Country
Help support the
Rc-Monster
Buy here
skellyo
skellyo's Avatar
02.22.2006, 09:23 PM
You might want to check out these Hyperion 20C packs:
http://cheapbatterypacks.com/main.as...id=tp&sort=V20
They only have up to 3700mah, but at 20C, that should be more than adequate, especially since they're rated at 30C burst for 30sec.
