Best pipe for Revo
$w!ft
Best pipe for Revo - 12.08.2005, 12:33 PM
Hey there guys i was thinking of getting a revo and was mainly stuck between engine and pipe to get.
Engines: Sirio .23 or the RB TM323
Pipe: Vantage Revo Carbon fiber pipe(any good?) or Fantom Revo Works Racing Tuned Pipe, natural finish.
Thanks for input.
Serum
Serum's Avatar
12.08.2005, 12:43 PM
Best pipe is one with a magnetic rotor in it..
Lol..
I don't know anything about nitro, but i know those vantage CF parts look awesome.. (don't know about their performance either to be honest..) (great help i am..?)
The vantage CF frame is one neat hopup too..
squeeforever
squeeforever's Avatar
12.08.2005, 09:16 PM
mike told me to get the rd racing. i would get the o.s. .18 tz
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
12.08.2005, 09:21 PM
ya .18tz or tm. Cant use the cf pipe because u need a BIG BLOCK PIPE. if u get the rb motor, it comes with it. If u get sirio, you'll have to buy a pipe and manifold which willb e a pain, cuz they dotn make many big block pipes/manifolds for revo.
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
crazyjr
crazyjr's Avatar
12.08.2005, 09:39 PM
I have a friend who has a sirio .23 and a trinity pipe and its scary the power it has
nbcaznmaster
12.08.2005, 09:41 PM
rb is even more powerfull, so i heard.
LSP-R - Picco .26
Nitro Revo - .18tm
$w!ft
12.09.2005, 05:37 AM
Are you telling my non f thses pipes will fit even though it says revo on them?
And maybe it is just easier to get the RB since it has a pipe and all? I can drop that one in immeditaly? and i can hook up EZ start to the RB?
wheeledgoat
02.23.2006, 05:05 AM
yeah, EZ start will work fine w/ the RB - i'm looking at getting the RB323 myself for several reasons; you don't need another engine mount, it comes with everything you need in one package, and i've had some friends tell me that it's a champ so far as keeping it's tune - only wide environmental changes necessitate messing around with the mixture. according to the 3 people i've talked to, once you complete your initial setup and get everything dialed in, you're solid.
i'm less inclined to go with the os.18 because you still gotta get a pipe and engine mount (and whatever else i don't know about). i haven't added up the numbers, but it sounds like the RB will be cheaper by the time it's all said and done.
another friend of mine put a trinity pipe on the stock 2.5R on his Revo - and even though it's labeled to fit the Revo, it's not as nice of a fit as the stock pipe. it takes a bit of fiddling to get it to not interfere with the rear rockers, including bending the thick wire it mounts to... and once you're done it sits at a weird angle. it works and all, but it doesn't look stock and it's not as nice as you might want...
$w!ft
12.09.2005, 05:41 AM
M323 power unit comes complete with a specifically designed exhaust manifold, exhaust pipe and engine mounting set to install this engine in your REVO without modification, and uses the original electric starter.
That just answered my question, i think ill go with this unless there is a good reason i should get a LST with novarossi 528 instead.
nbcaznmaster
12.09.2005, 07:37 AM
if u wnanna race, go with the .18tm, but bashing is crazy with the rb.
LSP-R - Picco .26
Nitro Revo - .18tm
$w!ft
12.09.2005, 02:53 PM
.23rb revo= 528 novarossi LST just about right?
squeeforever
12.09.2005, 10:52 PM
the rb isnt to much for the revo tranny? and what will perform better, os .18tz or the rb?
nbcaznmaster
12.09.2005, 10:58 PM
well, .18tz if u want race conditions. Rb if u bash. .18tz is a TOUCHCY Motor. many of my freinds cant tune it above 200 degrees cuz it becomes unstable then. the temps fluctuate alot. But the performance is incredible.
LSP-R - Picco .26
Nitro Revo - .18tm
squeeforever
12.10.2005, 02:40 PM
i've always been told there really easy to tune. not to mention if they are heat sensitive rd just came out with a head for them.
$w!ft
12.10.2005, 02:42 PM
will a rb revo compare to a novarossi LST???
