Hello,
Any suggestions or photo's on motor position when using G2 motor mount assembly? Having hard time positioning motors so they will not make contact with EVX. At this time using both stock motors and EVX.
G3 race suspension
X-brace chassis
G2 motor mount
:C:
You will probably have to put the motors up a position (not all the way down on either side). There are a few mounting positions available on the center mount, so you will have to find the position that clears the EVX.
Welcome to the forums, by the way!
Yes I am having the same problem. The motors wont clear the evx no matter what holesi use. :( I have G3 suspension G2 carbon chasis and the motor mounts.
