wiring batteries in parallel question
Riko
Riko's Avatar
wiring batteries in parallel question - 12.09.2009, 01:38 PM
Hi,
after some research it seems that big golden connectors are better than deans plug, because they should allow more current?
For instance these connectors from Hyperion:
http://www.allerc.com/product_info.php?products_id=4492
I am thinking of a parallel set up of 2 Hyperion G3 4200 mAh lipo's.
The cables are 10 ag on those batteries.
But I was wondering if the following parallel connection for 2 batteries could be made?
(the scale of the connectors is not so right :p)
I am not a solder-man, but I suspect you would have to make such a cable by yourself?
So I would need some 10ga cables and the hyperion connectors and thats it?
Edit: I think I've found something: http://www.hobby-lobby.com/g3.5_para...81149_prd1.htm
thx a lot!
You've been hit by, you've been struck by a smooth criminal
  Send a message via MSN to Riko
