Can the MMP handle a 6-Pole motor?
JoFreak
JoFreak's Avatar
Can the MMP handle a 6-Pole motor? - 04.12.2010, 05:32 PM
Hey guys,
the question is in the title: Can the Mamba Max Pro handle a 6 pole BL motor?
I'm asking here, because I didn't get an answer to my last mail to the support, and the answer to the mail before that took weeks...
Cheers,
Jo
Semi Pro
Semi Pro's Avatar
04.12.2010, 09:46 PM
depends on what 6 pole motor
what size is it?
i have seen one running a 1515 2.5d on 6cell for weeks with no problems
nitrostarter
nitrostarter's Avatar
04.12.2010, 10:02 PM
1515/2.5D is a 4-pole
N. Rustler conversion
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.12.2010, 10:24 PM
It would depend mainly on the RPM limit of the MMP, which I can't seem to find...
For example-
If the limit is 210,000 rpm with a 2-pole motor, then a 4-pole motor can be operated up to 105,000 rpm, and a 6-pole can be operated up to 70,000 rpm. Each motor has a mechanical limit, so make sure you don't exceed that. Yes, current draw plays a role as well, but a higher pole motor doesn't draw "more" current per say, just closer to DC current.
JoFreak
JoFreak's Avatar
04.13.2010, 12:01 AM
It would be a Tenshock 2220/6:
5000 rpm/V; Ri 0,004; Max. 12V; Max. 120A
6 pole
Length: 40 mm
Diameter: 38 mm
Diameter Shaft: 5 mm
Weight: 170 g
Max. Power: 1000 W
I would like to use it on 2S in a SCRT10.
So the question remains, can the mmp handle that kind of power in specific and that kind of motor (6-pole that is) in general?
What's_nitro?
04.13.2010, 12:24 AM
Well, the motor will never use that much power on 2s and I don't think you'll be near the rpm limit either.
himalaya
himalaya's Avatar
04.13.2010, 01:18 AM
Be careful to use Tenshock multipole motors. I was trying to drive a Tenshock 2230 with a HobbyWing Seaking 180A(same hardware as Ezrun 150A), it cogs badly when my finger pulls just half trigger. This ESC drives CC Neu 1515 2200KV and Medusa 36-80-1600KV(both are 4 pole) perfectly. Increasing timing advance can delay the cog to 2/3 throttle but never completely went away.
....What a Blue Sky....
JoFreak
JoFreak's Avatar
04.13.2010, 04:04 AM
Is this a problem with the tenshock or with 6-pole on the mmp in general?
nuz69
nuz69's Avatar
04.13.2010, 04:16 AM
You will have to find the best timing advance, probably between 15 and 20.
JoFreak
JoFreak's Avatar
04.13.2010, 04:58 AM
But will it be possible to at least nearly eliminate cogging?
nuz69
nuz69's Avatar
04.13.2010, 05:05 AM
If you find the best timing, yes. Do some tries at home at slow speeds, with a pc nearby to connect the link each times ^^
drkdgglr
04.15.2010, 03:44 AM
I've driven a TS 2240/10 with a mmpro on 6s and it only cogged once at half throttle. After that it never cogged again... I've only driven it 2 or three times though. I believe I didn't even adjust the timing.
