Mutilator
drkdgglr
Mutilator - 12.21.2009, 04:23 PM
I got myself an Ofna Mutilator rolling chassis. I know it's not the best truck, but I got it cheap, and it seems like a fun truck. From reading I've learnt that the only real weak point is the front king pin suspension setup, which can easily be upgraded to a c-hub suspension with the Mutilator pro front suspension. Also, as I've been browsing, it looks like the jammin x2 crt suspension could be used on the Mutilator. As I have to upgrade the front suspension anyway, I might aswell upgrade to the x2 crt suspension all around, giving me a little more width. The extra costs would be marginal.
I'll only use the Mutilator for bashing. So should I just replace the front suspension with the Mutilator Pro front setup of should I do the x2 crt suspension all round(of which I think it'll work, but I'm not sure)?
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
12.21.2009, 06:03 PM
Why not find a CRT or CRT x2? You're already converting most of the truck anyway. CRTs are pretty stout trucks, so are the Mugens if you wanted to get one cheap.
Or you could run it as is and see how it does since you're just bashing.
:D
drkdgglr
12.21.2009, 06:11 PM
I got the Mutilator cheap, and I like working on trucks. From what I've read the Mutilator is almost the same as the X1 CRT. That's why I got it. Also, I live in the Netherlands and there isn't an abundance of (cheap) truggy rollers for sale. And if I'd find one in the US, I'd have to pay about $60-$80 for shipping.
gtxracer
gtxracer's Avatar
12.21.2009, 06:21 PM
Ah, I see. Run it as is then!
:D
drkdgglr
12.21.2009, 06:30 PM
Well, I'll have to upgrade the front anyway as I've read the old kingpin suspensions setup breaks very easily.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.21.2009, 07:18 PM
A friend of mine had a Mut a while ago that the KP were already upgraded and it was a tank. It'll be a great basher !
Nard Cox
n00b
12.22.2009, 06:28 AM
I've seen the topic, was also questioning myself whether I should buy it or not, bet you got it REAL cheap since the seller wasn't asking for much anyway.
If I where you I would run it stock and when it breaks just upgrade to the x2 set-up.
drkdgglr
12.22.2009, 10:42 AM
Yep, I just wish the seller would put it in the mail....
I already ordered the Mutilator Pro front c-hub suspension with x2 crt front aluminum knuckles. It was the cheapest option. If I like the truck, maybe I'll upgrade to the X2 crt suspension later on.
I ordered a cc-neu 1518 1y for this truck and plan on running it on 6s.
gtxracer
gtxracer's Avatar
12.22.2009, 03:07 PM
I want action pics and vids with that 1518 on 6s
:D
Nard Cox
n00b
12.23.2009, 07:43 AM
That's going to be one sick ride
drkdgglr
12.23.2009, 09:17 AM
Hope it doesn't fall apart....
It's going to take a while before I have all the parts and time to (re)build the truck.
riverat1540
riverat1540's Avatar
12.23.2009, 08:57 PM
what size spur are u going to run, if it has the 62 like the crt x1 u wont have much room for a battery tray, i did the ring and pinion conversion o change the ratio so i could run 46-50 spur
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
drkdgglr
12.24.2009, 03:10 AM
could you tell me more about the r&p conversion? I thought this wasn't possible for the mut because there isn't enough room for a larger ring gear.
I was thinking of making a custom chassis if the batt won't fit.
superek4
superek4's Avatar
12.24.2009, 07:51 AM
u need to convert to x2 diff gear front & rear then you can use a smaller spur. I am using a 50 spur slip diff, that y i need to convert.
i am running a x1 btw.
Name:	batt tray3 (2).JPG
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
drkdgglr
12.24.2009, 01:53 PM
But, will the x2 crt diffs fit in the mut's transmission case?
I also noticed that Mike offers the slipperential with a mod.8 58t spur. This gives me another option, though IŽd have to run mod.8 pinion&spur.
