Cow R/C Jumbo Screw Catcher Review
Cow R/C Jumbo Screw Catcher Review - 01.11.2010, 04:44 PM
I recently acquired one of Cow R/C's "Jumbo Screw Catcher" work mats. While I honestly wouldn't have thought about purchasing something like this before, I will say it has come in quite handy already. I don't know about you, but I get tired of climbing under the bench to find tiny screws/nuts/washers in the shadows.
The whole mat measures 30" x 24" and is 3/8" thick. The main work area is 28" x 18.5", and is large enough to hold anything 8th scale and smaller, has a magnetic base to keep screws from bouncing into oblivion, and has convenient little tool/parts pockets. Each of the smaller pockets are 3" x 1.25" and are perfect for containing various screws, nuts, etc. The larger pockets are 8.5" x 3" and are large enough for most of those pesky hand tools that tend to roll off a bench. The entire base is magnetic and the bright white makes finding stray screws easy. The foam walls appear to be made of a neoprene type of material, so it should be sturdy and last a long time.
Now, on to the pictures!
Here is the mat fresh out of the box. The inserts are pre-cut, easily removeable, and can be used for future storage of the mat when not in use:
With all the inserts removed. The package also came with a few decals.
In this picture, you can see the thickness of the foam "walls".
This just shows how big the mat is compared to my not-so-clean Xray XT8 truggy.
And, here is a very small video showing how the magnetic base helps prevent screws bouncing if dropped.
