Awhile back I had doubted that the 36-70-1600 I have was actually 1600kv, I thought it might have been mis-labeled and was really a 2000kv version. Well I finally got around to hooking it up to my Eagletree with it on my E-maxx. I did this quickly inside with all the wheels off the ground just to get this reading. I used 2x 7cell nimh packs and the logger is hooked up to one pack so the voltage needs to be doubled. I have a peak RPM of 34,090 and at that RPM the aprox voltage was at 17.6 which equates to 1937kv. I would have to say that this confirms that I have a 2000kv motor which means that my sense of speed was correct and that I have never been geared correctly, I have always been way faster than what I was geared for which has put a tremendous amount of extra load on my setup. Currently my gearing should put me at the same speed as the stock brushed motors, but I'm def going faster. Now that I know I really need to gear for a 2000kv motor, I will be much better off.
I'm not so sure if you just got a motor that was labeled wrong OR if their kv rating system is messed up.
The reason why I say that is:
I'm running a Medusa 36-70-2000kv motor in my E Revo.
I also have the data logger with the brushless rpm sensor. On 6S, gearing 14/52, it says I'm spinning up to 65,000 rpms.
Now, I haven't quite figured out how to calibrate the sensor yet. I just got it. I don't think it's completely accurate on my setup, because it rarely goes back to 0.
There are times that I know the truck is stopped and it's still showing 7500 rpms.
If it's just a matter of zeroing it out to get the calibration right, this still leaves me spinning up to around 57,500 rpms.
This still leaves me at around 2500kv. hmmmm..............
I know this truck really screams with this setup. Gearing is for 40mph on 6S, but it's way faster than that.
I Know that roughly the stock Titans are about 1700kv, even though brushed motors aren't rated in kv thats roughly what they work out to be. With the stock gearing (68/19) and 4s lipo a stock E-maxx 3905 is geared to do aprox 25MPH. With a 1600kv motor and 68/20 gearing the speed should be about the same but it's no where close, I'm much closer to 30MPH which if I plug in a 2000kv motor it works out. When I had this motor on my RC8T I always thought I was way faster than what I was geared for and I tried putting in 2000kv then and the speeds I was coming up with seemed much closer to what I was actually doing. This just confirmed it.
I never calibrated the rpm sensor, at least I don't remember doing it, but it started at 0 and came back to zero in live mode
I just did this as a quick test with the wheels off the ground so amps didn't come into play. If it stops raining tomorrow I will do a run with the logger.
So how does the fact that it was pretty much unloaded for the test , come into play? It was my understanding that the KV should be taken at load. But mine always did end up being a little over the calc, so maybe they do something different, like take the KV at the full rated load. Then we put a much lower load, and the kv rises.
Af far as I'm aware kv values are for an unloaded motor, at least that's what I beleived the "U" after the value in Brian's calculator meant. I haven't posted up the graph yet but I did do a short run yesterday and I have still concluded that I'm much closer to 2000kv. Everytime I do the math I come up between 1925-1960kv. It's tough as the only way to figure it out is at full throttle and figuring out where I hit full throttle can be tough, that's why I had started with a quick test just holding the truck in the air, I could grab full throttle and hold it there. I'm gonna do another test when I can have a friend help. I want to hold full throttle for a bit and see where everything stabilizes.
