Closed Thread
Brushless CRT + Associated TC4 + Rustler VXL !Open to offers!
BL-revo
Brushless CRT + Associated TC4 + Rustler VXL !Open to offers! - 04.02.2010, 11:03 AM
First up is my TC4 touring car. Good used condition with lots of spares pictured and a full box of wheels and tyres. it comes with a towerpro mg995 on the steering and 3 bodyshells one of which needs fitting properly.
All pictures can be found here-http://s136.photobucket.com/albums/q183/cashmerebear/TC4/
So needed to complete is a motor, esc, battery and Transmiter/receiver
Next is my CRT Full pro - Full brushless conversion by RC product designs. It comes with 4 shells, plenty of spares including shocks driveshafts a chassis... e.t.c It comes with front and rear Innovative IRC shock towers and 2 black IRC alloy diff cups all BNIP
Pictures can be found here - http://s136.photobucket.com/albums/q...hmerebear/CRT/
can do in the following ways:
roller with the IRC parts
everything minus the servo and receiver
everything + Ace ds1015 servo and spektrum receiver
I also have a rustler VXL up for sale
it comes with a brand new chassis, front bulkhead and upper chassis (still in packaging not fitted as i haven't had time to fit them yet)
the original chassis, bulkhead and upper chassis cracked because the bulkhead 1st broke i didn't realise and that put alot of strain on the rest...
it has RPM - front and rear shock towers, front and rear arms, front hubs and front castor blocks as well as a bumper.
it has a bent integy wheelie bar that could be bent back and integy rear hubs
it comes with the worn and cracked stock rear wheels on stock tyres
the anaconda and alias black wheels front and back in good condition + a spare nip wheel
the transmission is fine but could perhaps do with a bit more grease as it does let a bit too much power go
the stock front shocks are fine but just need topping up with oil but the rears are a little bent
i have a set of 1/8th buggy shocks on the rear at the moment and they are super strong so i have just left them on there.
there are 4 buggy shocks, the shorter ones are on the back of the rustler and the longer ones aren't being used
there are quite a few sets of springs for the buggy shocks too (i think 2-3 full sets including the ones on the shocks)
i was using 1/10 buggy shocks on the front (the rear buggy shocks on the front of the rustler if that makes sense)
there are a full set and again there are more than 1 set of springs. if you want to do speed runs you can fit these shocks as it lowers the car alot and keeps it more stable
the bodyshell is a beaten up but with spacers e.t.c you can get it to sit tight...
Pictures can be found here - http://s136.photobucket.com/albums/q...hmerebear/VXL/
All prices do not include postage and packing and i would like the money as a gift through paypal/ cash / cheque
My feedback on ebay can be found under Terzo53
Thanks richard
BL-revo
04.02.2010, 12:07 PM
hi guys, i have 3 sets of lipos for sale ( please note i will not split the lipos up unless 2 people are interested in 1 each...):
2 X Zippy-R 4500mah 21/30C 14.8v/4s lipos perfect for 1/8th scale setups. in good condition approximately 30 runs in total and matched to each other so you can use them in parallel for a whopping 9000mah single battery. an extra layer of clear heatshrink has been added for extra protection and one of the batteries has a small tear in the white heatshrink below this but this doesn't effect how it runs
2 X FTX 5000mah 20C 7.4V lipos again perfectly matched to each other so they can be used in series for 14.8V of voltage
(the heatshrink on the wire has cut near the exit of the wires from the hardcase but this has been taped and i can heatshrink before i send it out if you want. there are scratches on them but none are serious)
Enerland/ polyquest 18.5V 6000mah excellent top quality battery RRP of £160+ less than 10 cycles through it and double heatshrinked for extra protection
all prices include 2nd class recorded delivery if you want them insured (advised as recorded is covered only up to £39) i will find out how much extra it will cost.
BL-revo
04.02.2010, 12:08 PM
Right a proper clearout this time plenty of stuff for 1/8th buggies truggies 1/10th trucks touring cars + More.
Starting off with truggy tyres:
proline max mulchers on proline yellow dished rims. excellent condition very little use 90-95% tread left if not more !
proline bow-ties on proline white dished rims again excellent condition very little use 90-95% tread
same again proline yellow dished rims with proline badlands excellent condition 90-95% tread
First person to buy a set gets the tyre holder :)
Some 1/8th buggy tyres and wheels:
proline crimefighters on proline dished rims excellent tread
proline badlands on proline dished rims excellent condition
proline crimefighters again on yellow spoked proline wheels excellent tread
HN power grip on road 1/8th tyres require reglueing and new foams for 2 tyres and the centre of the tread of one tyre needs to be repaired somehow (split in the tyre which could probably be melted back together) -
Free set of worn tyres (perfect for on road use) for whoever buys the first set :)
BL-revo
04.02.2010, 12:09 PM
Now onto the motors
first up is a 9xl (1900kv) brushless motor with rc-monster clamping heatsink (will sell seprately if wanted)
2nd motor is a tekin redline 6200kv sensorless motor good working condition
Spektrum Dx3 system with 2 receivers (both have had repairs done to the aerials) boxed in good condition
Mod 1 pinions - 13,15 and 16 tooth good used condition very little wear to the teeth.
AA/ 9V battery charger
True rc 3200mah lipo quite old but still works therefore
Lipo safe pouch
Tower pro mg995 servo
ESC unsure whether it works or not
Failsafe not sure if it's working
I will do deals on more than 1 item e.t.c
my feedback can be found on ebay under terzo53 and also on this forum just search my username in the feedback section :)
thanks richard
04.02.2010, 12:11 PM
No prices please - You missed that on the last post
Closed Thread
