User operated fan (or other)
pinkpanda3310
pinkpanda3310's Avatar
User operated fan (or other) - 04.11.2010, 04:27 AM
I'm not convinced my fan on the mmm is coming on when it needs to. The previous unit the fan would come on regularly, my ir gun would read 40-45C through the side. Now i get readings 50C+ but no fan. I know it works cause it spins when the mmm is turned on.
Anyway I did some searching and found the NERS and MERS switchs. I don't have telemetry but I reckon this would be a good accompanyment if you have enough channels in the reciever.
I don't know if these are old hat but thought you might like to know if you didn't and if you did know then could you share your experience. I haven't ordered one yet.
04.11.2010, 10:23 AM
Seems kinda more money, hassle & wiring than is needed. Just swap out the stock fan for an aftermarket 25mm item, and put an rx plug on the leads = permanently on fan that will lower MMM operating temps throughout the whole run, rather than kick in once its already starting to overheat...
pinkpanda3310
04.11.2010, 10:48 PM
Fair comment Neil. I knew of that method but the idea of being in control (and the extra gadgetry) seemed apealling to me. The mers is quite a bit extra wiring and hassle.
btw are they still making red dwarf? I haven't seen it in years.
04.11.2010, 11:09 PM
If all you want is something that can be turned off/on via CH3 of your radio, save a few bucks and recycle one of your old unused servos.
pinkpanda3310
04.12.2010, 02:50 AM
Oh yeh, I completely forgot about that thread BG. I don't know how you come up with these ideas
Bazzokajoe
04.12.2010, 07:51 AM
My fan does the opposite, ever since i bought my mmm the fan is on constantly, as long as the esc is on the fan is on...
is this a problem?
04.12.2010, 09:46 AM
Madness. Pure madness.
is this a problem?
It is a problem in that it doesn't operate as it should and therefore something is wrong, and may wear faster since it is seeing more usage. But, it's not a problem in that the ESC stays cooler since it is on all the time. Depends on how you look at it.
04.12.2010, 03:21 PM
I like that servo/fan idea, time to fire up the soldering iron..
Redwarf = last series was several years ago, but they made a mini-series that went out on a non-terrestrial chanel & then went pretty much straight to DVD; by all accounts it was rather crap. I might pick up the dvd regardless though; die-hard fan & all that...
