Mike's Lipos..?
Sylvester
Sylvester's Avatar
Mike's Lipos..? - 01.28.2007, 04:51 PM
I was wondering if mike stocks the new 20C HV cells? I was wanting to get the 8000mah 2s2p pack but wasnt sure if i should, since mike doesnt have a option to take 12ga wire.. Thanks.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
crazyjr
crazyjr's Avatar
01.28.2007, 05:41 PM
I bought my 8000 mah battery packs from mike (2s and 3s) and they are the 20c ones
Sylvester
Sylvester's Avatar
01.28.2007, 05:43 PM
Thanks Larry.
Losi 8ight e
01.28.2007, 07:22 PM
How can you tell? I just got 2 x 2s 8Ah packs and am curious as well. I don't plan to run them anywhere near that high, but it would be nice to know...
crazyjr
crazyjr's Avatar
01.28.2007, 09:01 PM
It said in the store they are. also i have made several hard runs on mine with a 9XL and 7XL and they never get hot. My eagletree says i pull several 100 amp peaks in a few minutes of running (hard takeoffs on pavement) and not getting any heat off the packs
Sylvester
Sylvester's Avatar
01.28.2007, 09:34 PM
Thats good to know. I love mikes fast shipping.
Losi 8ight e
crazyjr
crazyjr's Avatar
01.29.2007, 03:31 PM
Yeah he can't be beat
Sylvester
Sylvester's Avatar
01.29.2007, 05:51 PM
Unless you get UPS 1 day shipping, but even then, import duties suck @$$!
Losi 8ight e
crazyjr
crazyjr's Avatar
01.29.2007, 05:55 PM
I did some testing on my eagletree for other things, but paid close attention to the volts to amps and saw that at 105 amps, the maxamps were holding 3.2vper cell, this was about 30 seconds into the run and the run lasted for about a minute and a half
Serum
Serum's Avatar
02.01.2007, 07:36 AM
You can´t tell Brian.. Weigh and size is the same. How odd..
neweuser
neweuser's Avatar
02.01.2007, 01:05 PM
Hey larry, can you do some more testing of the cells with longer runs perhaps? I'm curious to see what they are doing later on in a run.
crazyjr
crazyjr's Avatar
02.01.2007, 08:03 PM
I have run the 5s setup in the G2R (9XL/MambaMax) for over 30 minutes, Broken up over two runs, First only ten minutes and the second over 20before charging. thats over 30 minutes and it was as fast as it started.
On a side note, My testing on the eagletree has only been around a minute and the drops i see in the batteries are interesting, With a full charge (20.88), I have seen drops to 16.24v and amperages over 110 amps and wattages over 1900 watts in the minute long sessions. Weather has been a problem so longer sessions will have to wait
