FS: Losi MRC Tuber
gimpygolden
gimpygolden's Avatar
FS: Losi MRC Tuber - 06.26.2010, 01:17 PM
I've got an MRC with a Metal Fume Fab "Skunk" tube chassis
It's also got brand new MIP shafts and a Futaba S9551 Low-Pro Digital servo.
Also has:
Stainless steering links
RC Bros: lockers fr&r, servo mount, battery mount, Delrin high clearance links
Losi: alloy shocks(Droop), center locker, front cvd's, Mini Blue Rock Claws w/Mem foams, alloy wheel hex's
Holmes Mini Torque Master motor w/extra brushes
Tekin B1r ESC
Mahem Eng. 7 Wheels Blk w/Silv Star rings outside-standard ring inside(gives 2 different looks if you switch em)
TCS: 3 link plates, axle support plate,Upgrade hardware kit, Internal shock springs Soft & Med
3x Rhino 610 2s LiPo
1x Rhino 410 3s
stock motor,esc,chasis & body never used
Stock wheels have weights and the rings are there to make them functional beadlocks.(I find these work better on the couch than the Blue Claws)
The 3 blu foams are what came with the blue Claws, if I find the 3rd it will be included
1 axle is starting to click when really loaded, included is a Diff shim kit which should fix it right up.
Have spare axle housings, complete screw kit, plus all stock take off parts minus the Trans & Rec
The Futaba receiver in pics is not included
All in all this truck has less than 10hrs use on it, but it was fun to build.
If you have any questions don't be afraid to ask, I'll try my best to answer any Q's fast.
PM for new lowered pricing
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
