motor shaft too short
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
motor shaft too short - 06.26.2010, 01:44 PM
is there anything on the market that makes a 5mm shaft on a motor longer? an extension maybe?
i have a motor that i wanna use and after it mounts to the motor mount, it's just too short for any pinion to grab. any solutions?
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.26.2010, 01:49 PM
Impaktrc has Long Shank Pinions. Would that be an option for you?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
DwightSchrute
06.26.2010, 01:54 PM
i thought about those, but it's for a traditional 8ight mount. the collar of the pinion where the set screw places dosen't quite clear the inside part of the mount. it needs to be a smaller collar. that's kinda why i was thinking about an extension of some sort. almost like Mike's bore reducer. i may really have to hack up the mount to use it.
thanks for the idea though. it might be a last resort option to make the center hole of the mount bigger. then the tekno pinions would work.
bryan
bryan's Avatar
06.26.2010, 02:01 PM
What motor are you using? Got any pix?
DwightSchrute
06.26.2010, 02:19 PM
no pics yet, it's not quite finished. it's a feigao 6L motor on a traditional losi 8ight motor mount. by the time i use Mikes front endbell protector and endbell clamp, i'm out of room.
06.26.2010, 04:18 PM
Are you using both at the same time? Just use the clamp, and some electrical tape to cover the holes.
Any kind of shaft extension would have to be perfectly centered & a perfect slip fit, otherwise it would introduce wobble that would kill the front bearing in the motor.
DwightSchrute
06.27.2010, 08:45 AM
thanks for the replies, much appreciated.
i'm just gonna get another one of Mike's mounts. Seems like he makes the best of the best stuff. there's no point in messing with perfection.
