FS: everything rc i own asap
strodedawg
FS: everything rc i own asap - 07.06.2010, 08:55 AM
Due to my recent job situation i need to sell all my rc gear asap
1- ARTR tekno converted rc8t ce
just add your radio
j concepts body and wing
set of 2 race day old soft crosshairs mounted on jc half-ups
set of new unglued sevens mounted on jc half-ups
set of one run double dees on jc half-ups
de racing skid plate and mud guards
electronics
-tekin 1700kv/rx8 system 8 runs
-rc-monster 5s lipo hardcased
-xp1015 servo
M2C rear hubs w/ 4mm rear hingepin
narrow hubs
complete spring set
tekno stuff:
-complete nitro clutch set-up w/ all option springs
-complete traktion clutch w/ all option springs
-14 tooth tekno clutch bell
-14 tooth tekno pinion
-complete brake set-up for meechanical brakes
-servo included xp1015
2- custom 2wd race emaxx
never ran all parts are new except bl motor
tested in the street for 3 min to see if electronics worked
1-chassis designed with the help of kershaw designs
-low cg and light
-slipper
-aluminum chassis and upper deck
3- sealed diff w/ 5k oil
2- hardened drive cups and thick center drive shaft
4- rpm true track rear suspenson
5- mip cvds
6- rpm oversized bearing front knuckles
7- new emaxx 16.8 steering rack
8- new jconcepts rims
9- new soft jconcepts goosebump rear tires
10- new imex med/soft ribbed front
11- aluminum steering arm for a futaba servo
12 associated 13mm shocks on rear
13- ofna 13mm shocks on front
14- pinion included (25t)
15- fullforce rc aluminum towers
16-rpm skids on both ends
17- springs and spare shock parts
Included electronics:
castle creation mamba monster
tekin 1700 kv truggy motor
transponder
zippy 4s 4000mah 40 c lipo i charge to balance it
needs a servo, receiver and body ( can use servo from brake set-up above)
all paperwork i have and a suggested set-up from traxxas
3- RC18t2/b2 partially built kit
Ae servo new and never ran installed
complete set of cvds from mip (can't use with stock diffs)
12mm adaptors
set of touring foams
shocks not built
one stock axle is too short and wont thread nut on
one turnbuckle wont thread into ball cup ( defective)
all paperwork, parts and box included
4- electrifly triton EQ2 charger
ac/dc
lipo up to 6s
has deans plug adptor and alligstor adaptor for charging
balancer and temp probe
Looking to sell as a whole
paypal prefferred
any q's or additional pics pm me or
strodedawg@gmail.com
will ship asap as the money is needed
ID:	9114   Click image for larger version
ID:	9115   Click image for larger version
let's build something sick!
