Instead of a Pinion, Use a clutch bell? and double check my gearing please.
Jahay
Instead of a Pinion, Use a clutch bell? and double check my gearing please. - 07.16.2010, 05:41 AM
Hi Everyone!
Firstly... Thanks to simplechamp for delivering me this awesome ofna centre diff!
I am quite shocked by how amazing the build quality is!
Question 1
Anyway, as i decided against the slipperential and because i am converting my savage flux to a CD rather than a tranny which has a slipper... I feel i may need some sort of give in the drive line....
I saw somewhere but i cant remember, someone using a clutch bell and pads to protect the motor. Basically a nitro setup...
Is this easy enough to do? Would it be possible for my 1520? And is it necessary taking into considering the weight etc of my ext savage?
Question 2
I just want you guys to check that my gearing is correct before i buy the wrong pinions. I am just a little confused as it looks ill be using 9t-11t pinion to get my desired speeds... Smaller than i have ever used (never had a centrediff)
Does this look correct? These are the speeds that i am running now with my current 18/47 gearing, and with no heating issues etc... so i am looking to maintain these speeds with the centre diff....
Thank you
