K-Factory Rocker Arms "RARE"
DR STATIC
DR STATIC's Avatar
K-Factory Rocker Arms "RARE" - 04.08.2011, 03:26 PM
"RARE" I have three (3) sets of NIP front & rear Revo Rocker Arms.
The Traxxas Revo’s suspension is one of the best suspension system among all monster trucks (IMO). The Revo utilizes nylon rocker arms to adjust suspension travel. To make it easier for racers, K Factory has created a adjustable aluminum rocker arm set, 2 for front & 2 for rear. With K Factory aluminum rocker arm set, you just need to adjust different positions to set up the suspension travel you need. No need to carry lots of stock rocker arms with you.
On these Revo aluminum rocker arms, we use aluminum as back bone & carbon plate stiffener. This helps to increase the overall quality. The carbon plate is attached to the alum. rocker arm with new K Factory strong lightweight button screws. The combination balances stiffness & lightness. When using K Factory alum. rocker arms, the suspension has no additional play because every part is well machined & tested.
ID:	9885   Click image for larger version
ID:	9886   Click image for larger version
