mamba monster swolen capacitor
nvtuning
mamba monster swolen capacitor - 06.02.2011, 04:55 PM
dear castle;
I was driving my flm savage yesterday and at some moment it started cogging so i checked the battery voltage's and they where 3.76volt per cell
so i tryed again but it didn't want to move anymore when i use only one battery (2 cells) it works great but with two packs (4cells) again it does nothing.
But after opening up the case i saw this this can't be good what should i do.
the setup i'm running is:
mamba monster (ofcourse)
the 2650kv motor from castle (the one that came with the esc)
and 2x 2cells lipo's 5400mAh (in series so it becomes one 4cells)
already thanks
greets nvt
rc8te/NEU 2200kv/mamba monster/4cells lipo
savage/castle 2200kv/mamba max pro/4cells lipo
scx-10/castle 4600kv/mamba max/2cells lipo
06.02.2011, 07:58 PM
What brand are those lipos, and the C rating?
Swollen cap is usually a sign of ripple current caused by poor batts or maybe overheating- you could in theory replace the cap but it would be better to return the whole esc for testing & servicing- there is a form on the support page to fill out with return details:
http://www.castlecreations.com/support.html
nvtuning
06.03.2011, 04:24 AM
battery's used are zippy 2cells 5400mAh 25C
greets nvt
Pdelcast
Pdelcast's Avatar
06.03.2011, 01:11 PM
Couple of things...
25C battery... we suggest a 35C battery (remember, cars like ERevos and Savages draw around 300-400A during acceleration -- The higher the C rating, the better the batteries will handle it.)
Connectors -- THOSE little bitty connectors you have on there are going to kill things. Too much electrical resistance = BAD. I don't even know how you soldered the 10ga wires on those connectors. If you continue to use little connectors, you will continue to have problems. We suggest the Castle 6.5MM connector for Monster setups.
Long battery wires = BAD. Keep 'em short!
Patrick del Castillo
President, Principle Engineer
nvtuning
06.03.2011, 03:26 PM
i understand those connectors are bad but 25C on a 5400mAh battery is good i think
better 25C on a 5400mAh battery than 40C on a 2200mAh one
greets nvt
Pdelcast
Pdelcast's Avatar
06.03.2011, 03:39 PM
greets nvt
That's true -- 25C on a 5400mah battery IS better than 40C on a 2200mah battery -- but I personally wouldn't recommend either of those batteries with a Mamba Monster.
All of these things add up to make it hard on the ESC, and especially on the capacitors.. The capacitors are there to keep the voltage at the ESC as smooth as possible. If you use connectors that are too small, and batteries that are too low C rating, the results are damaged capacitors.
Thanx!
Patrick
nvtuning
06.03.2011, 03:56 PM
Thanx!
Patrick
ok i'll try to change the capacitors and see if it works and get some new battery's thanks for your help
greets nvt
Pdelcast
Pdelcast's Avatar
06.03.2011, 03:57 PM
greets nvt
Well, we can get it fixed up for you -- I wouldn't try repairing it yourself.
Contact tech support @ castle and see what they can do for you.
Thanx!
Patrick
bruce750i
bruce750i's Avatar
06.03.2011, 03:44 PM
yes, and better yet a 40c 5000.
nvtuning
06.03.2011, 03:58 PM
ok i will thanks for your great products and service
keep up the good work
greets nvt
