loooking for 3s batts that will fit in the slash 4x4 tray
loooking for 3s batts that will fit in the slash 4x4 tray - 10.23.2010, 10:49 PM
For all of you who are running the slash 4x4...what 3s batts do you use/will fit with the stock tray set up
slimthelineman
slimthelineman's Avatar
10.23.2010, 11:54 PM
I've been runnin thunder power 3s 3200 40c since I bought the truck. Most hardcase 3s packs will fit but I have also used some turnigy 3300's as well. The turnigys work well too but fit kinda loose in the tray. Had the tp packs when I got the truck and just keep usin em cause they fit and work very well in 5-8 min races and weigh the same as a 2s 5000 ~300g
10.24.2010, 10:34 AM
Thanks for the reply. What I am looking for and wishing for perhaps is a 5K 3s soft pack that will fit
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.24.2010, 10:50 AM
HobbyShity 3s 5000mah 30C fit beautifully but the tray needs a small notch for where the wires exit the pack.
HobbyPartz 3s 5000mah 40C fit also and require the notch as well in the tray.
JThiessen
JThiessen's Avatar
10.24.2010, 02:20 PM
I'm running some of these - fit nice in the Slash, and in my Flux trays.
http://www.rc-monster.com/proddetail...p303s2p&cat=18
Also running some zippy 4300's. My Hyperion 6K's dont fit.
10.24.2010, 03:00 PM
Just so happen to have 2 of those I am using for another project. I did check and the are perfect...many thanks!
Looks like I will be adding more batteries to the stable soon...like having 12 now is not enough
10.24.2010, 02:26 PM
What about running them "on-edge"? Yeah, it raises the COG a little, but it's an option. I did this in my 2wd slash because I didn't want to cut a notch in the chassis and wanted to fit a 4s pack in there.
