Go Back   RC-Monster Forums > Questions and Answers > Frequently Asked Questions (FAQ)
Thread Tools Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
Triple Diff Basics
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
Triple Diff Basics - 12.28.2006, 02:01 PM
TRIPLE DIFF BASICS
(This article is from RCDRIVER)
<o></o>
Tuning your Diffs
Most diffs are designed to be filled with viscous silicone fluid, which alters the diff’s tension, i.e. makes it “LOOSE” or “TIGHT”. What this is really doing is changing the diff’s “limited slip” properties. A loose diff will send more power to a wheel that loses grip, robbing valuable power to the wheels that have traction.
Some general rules that can be applied for diffs.
<o></o>
GENERAL DIFF RULES:
A looser diff provides more traction and will enable vehicle to work better on rougher surfaces. A stiffer diff works better on high grip conditions and improves acceleration and throttle response.
<o></o>
FRONT DIFF:
A good starting point for 1/8 scale biggies and truggies, is to fill the front diff with 7k wt. silicone fluid. Using thinner fluid will loosen the diff’s action, improving steering response, but will also tend cause a decrease in stability under hard acceleration, as the front wheels will more likely to pull to one side or the other in reaction to the chassis transverse weight and to irregularities in the running surface. Thicker fluid enables the front wheels to pull harder and with greater stability, and on-power and high-speed steering will improve, but you will lose some off-power steering response, especially in slow turns. Try to use fluid no thinner than 3k or thicker than 10k in the front diff.
<o></o>
CENTER DIFF:
Buggies- start by filling the diff with 10k wt silicone. This usually provides a good combination of acceleration and stability. If your vehicle leans toward over-steer when exiting turns, using thinner fluid such as 5-7k in the center diff will send more power to the front wheels, allowing them to pull harder. At the same time, drive to rear wheels will be slightly diminished. The shortcoming is the overall acceleration will be reduced, as more power will be sent to the unweighted front wheels, while less goes to the rear wheels.
A looser center diff will improve off-power steering response, as it reduces wheel-slip, thus inhabiting understeer, or push, by allowing the front & rear diffs to function more independently during cornering.
A tighter center diff sends more power to the rear wheels , thus allowing the car to be “ steered” more by the rear wheels, increasing on-power steering.(but at the loss of stability on slippery surfaces)
<o></o>
Truggies- It is not uncommon to use 20k or even 30k silicone fluid in a truggies center diff to compensate for the extra heft and rotating mass of the tires. If the tires tend to expand hugely during acceleration, thickening the fluid the front diff and center diff is often a remedy. Some drivers have run up to 20k diff fluid in front diff to reduce tire expansion.
<o></o>
REAR DIFF:
Of the 3 diffs found in the vehicles, the rear is run the loosest. This is done in a effort to achieve maximum traction from the rear wheels- during acceleration as well thru the bumps. Most racers fill their diffs with 1k-3k, but no more than 7k. Using anything thicker will create a condition of oversteer when exiting turns, making the vehicle the vehicle difficult to control in almost any conditions.
<o></o>
This article was originally written: by Frank Masi of RC-Driver
Copied by: Shayne Richardson
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
Serum
Serum's Avatar
12.28.2006, 05:08 PM
Great info. let's make it a sticky..
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
03.06.2007, 05:51 PM
dont know if this is usefull:
Differential Fluids
Changing the viscosity of the fluid in the differentials affects the way the car
handles and performs. The Turmoil™ differentials come pre-filled with 5000
wt. in the front and center and 1000wt. in the rear. For most conditions, this
is a good place to start.
Center: Changing the fluid in the center differential affects the front-to-rear
drive. To conceptually understand how the front differential affects handling,
think of it as front-wheel vs rear-wheel drive. Heavier diff fluid gives more
rear-wheel drive effect, resulting in more acceleration and more on-power
steering. Lighter fluids in the front differential allow it to unload during
acceleration, giving more front-wheel drive and reducing power-on steering.
When your car under-steers during acceleration, try switching to heavier
fluid in the center differential. When your car over-steers during acceleration,
try switching to lighter weight diff fluid in the center. Typically the optimum
center differential fluid is between 3000 to 10,000wt. depending on the track
conditions (slick surfaces = lighter center diff fluids).
Front: The viscosity of the fluid in the front differential affects overall
steering authority. Heavier fluid reduces steering while lighter fluid gives
more steering. However, if the fluid used in the front diff is too light, the
steering can become inconsistent, especially when accelerating from corners.
Typically the optimum front diff fluid is between 3000 to 7000wt.
Rear: The fluid in the rear differential affects cornering traction and overall
steering. Lighter fluid in the rear diff gives more cornering traction and more
steering, while heavier fluid reduces rear side bite while reducing steering
authority. Some racers replace the fluid in the rear differential with thin
grease for even greater rear cornering traction. Nearly all the racers use
1000wt. fluid or light grease in the rear differential to get maximum rear end
losi 8ight-t
xray xt8
11.13.2009, 10:38 AM
DIFF OIL
THICKNESS CHARACTERISTICS
Front
Thinner
• Increases steering into corners (off-power)
• If oil is too thin the steering may become inconsistent,
especially it can lose forward traction (and steering)
during acceleration out of corners
Thicker
• Increases stability into corners during braking
• Increases steering on-power at corner exit
Center
Thinner
• Front wheels unload more during acceleration
• Decreases on-power steering (reduces oversteer)
• Easier to drive on rough tracks
• If a high-power engine is used you could waste too
much power and sometime “cook” the oil in the center
differential because it “overloads”
• More off-power steering
Thicker
• More all-wheel drive effect
• Better acceleration
• Increases on-power steering (reduces understeer)
• Better suited on high-bite, smooth tracks
• Car can be more nervous to drive especially if a high
power engine is used - you might need to be smooth on
the throttle
Rear
Thinner
• Increases cornering traction
Thicker
• Decreases rear traction while cornering
• Reduces wheelspin
