For those of you who follow my MGT build thread you probably know I recently purchased a mini mill. For those of you who don't follow my build thread, I recently purchased a mini mill.
Anyway, long story made short, I've gotten it all setup, and have been using it ALOT since then. I figured making a thread like this (review & upgrades) will help others when considering buying a mini mill. Here is a link to the mill I purchased -
https://www.littlemachineshop.com/pr...ory=1387807683
So here are some of the key details about the mill I bought -
| End Milling Capacity | 0.6" (16 mm) |
| Face Milling Capacity | 1.2" (30 mm) |
| Drilling Capacity | 0.5" (13 mm) |
| Table Size | 18.1" x 4.7" (460 mm x 120 mm) |
| T-slots | 3 slots 0.47" (12.0 mm) wide |
| X-Axis Travel | 11.8" (300 mm) |
| Y-Axis Travel | 5.1" (130 mm) |
| Z-Axis Travel | 9.3" (235 mm) |
| Throat | 6.5" (165 mm) |
| X- and Y-Axis Feed Screws | 0.062" (1.59 mm) per rotation |
| Head Tilt | 45°- 0° - 45° |
| Positioning Accuracy | 0.0004" (0.010 mm) |
| Spindle Taper | R8 |
| Spindle Motor | 0.67 hp (500 Watts) |
| Spindle Speed | 100 - 2500 RPM |
| Power Requirements | 120 V 60 Hz 8 Amps |
| Machine Weight | 121 lbs (55 kg) |
| Overall Dimensions (W x D x H) | 23.2" x 19.7" x 29.1" (590 mm x 500 mmx 740 mm) |
Something also important to note. The following mills, including the one from LittleMachineShop.com, all come from the same factory. Sadly, made in China, but according to the comparison chart from LittleMachineShop.com, all have about the same general quality, but some have better features (and price points) than others. My personal opinion after comparing a Harbor Frieght mill (in person) to my LittleMachineShop.com mill, the LMS mill is of a higher quality. Take a look at this comparison chart, gives the stats on all of these similar mills -
(see next post for the chart, damn this 10,000 character limit!!!)
