Is it normal????
neweuser
neweuser's Avatar
Is it normal???? - 04.27.2006, 03:26 PM
Is it normal for the motor to get warm when you plug the batts in and you don't run it?
Sylvester
Sylvester's Avatar
04.27.2006, 03:53 PM
Not really, how long were the batteries connected?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
HotnCold
HotnCold's Avatar
04.27.2006, 04:26 PM
I would say - no - and i dont think it matters if you have the batts plugged in - the motor shouldnt get hot.
Hows that "Hope and Change" working out for Ya???
Dafni
Dafni's Avatar
04.27.2006, 04:34 PM
Well, if you just plug it in and let it sit, it should definitely not get worm. When you drove it, however, it will get a bit warmer when you let it sit. Reason being the sudden lack of airflow. Heat gets not generated in the can, but inside the motor. And it get's only cooler on the outside, where it has contact with the air. If your truck moves, air flows over the can and displaces heat. But when you stop, the heat distribution in/on the motor gets more even (magnet cools down, while the can might get warmer)
No new heat is generated, though, it just moves to the cooler area.
Hope this helps
DAF
neweuser
neweuser's Avatar
04.27.2006, 04:24 PM
Last night i ran it for about 3 min, drove it by me to feelthe motor. It was warm. I let it sit for a minute or more, and it was even warmer? It seemed like it was getting wrmer the longer it sat. Then i drove a little more and it became cooler again? Weird...I have a thread going in General electric about the batts to see if that could be my prob. But also my batts are only a few months old....
neweuser
neweuser's Avatar
04.27.2006, 04:38 PM
helps greatly, i think that's what's going on. It doesn't get hot fast so....I guess a lot to learn with brushless!!!! This will be interesting! thanks guys!
Dafni
Dafni's Avatar
04.27.2006, 05:04 PM
Welcome. And it's not necessarily a BL related phenomenon, you find this everywhere. Sudden lack of cooling/airflow, while more heat is traped or stored inside a body. Nitro engines are another example. When you measure the temp on the head directly after a run, shut it off and wait a moment, the actual temp on top of the head increases a bit.
In E motors this effect might be more drastic, because our magnets and windings store a lot of heat energy. (relative high effective heat capacity)
Gustav
Gustav's Avatar
04.27.2006, 05:28 PM
Like in racing when brakes set on fire in the pits or in parc ferme after a race,that's why they have a cooling down lap.
neweuser
neweuser's Avatar
04.27.2006, 05:25 PM
That makes tons of sense....great explaining man!
