WindowsXP Question
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
WindowsXP Question - 04.29.2011, 09:05 AM
So I've been using Taskkill to close Windows Media Player through Task Scheduler via a .batch file. I put music on when I go to bed and set it to close an hour later. Now, for some reason, the batch file won't do it's job when opened through the Task Scheduler. If I open the batch file directly (right-click, open) it works fine. If I go into Task Scheduler and manually run the task, I can see the CMD window flash- so I believe it is opening the batch file, but it doesn't close WMP. Nothing has changed (to my knowledge) since two nights ago (the last time it worked) so I don't have a clue what's going on.
Wierd, huh?
