Ordered an electric 'motorcycle', err... scooter
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
Ordered an electric 'motorcycle', err... scooter - 07.16.2012, 03:54 PM
hey guys, long time no see. i've been busy with home-ownership stuff and haven't had much of a chance to play with toys...until i saw this:
100% brushless electric (rear hub), max mph: 30 mph, distance per charge: 40 miles.
it has a 48-volt, 80-amp SLUNCE battery pack that provides up to 2,000 charges, with a charge time of 2.5-4.5 hours.
here are more specs - anyone have experience with one of these? at a price of $1250, i had to order one. my head is reeling with ways to mod it - but i'm not familiar with that controller (interesting that it's a USB controller)
• Frame Type—Maxi-Scooter
• Frame Material—Steel Alloy Wheelbase of 64"
• Rear Suspension—Adjustable Tension Coil-Over Shocks
• Fork—1-3/8" Single Crown Scooter Fork
• Total Weight—386 Pounds
• Cargo Capacity Max—295 Pounds
• Motor Type—High Output Sealed Permanent Magnet Brushless Direct Current (BLDC) Rear Hub Motor
• Peak Power—1.5 kW at 4500 RPM
• Peak Continuous Current—60 Amps
• Torque—200nm at 0-1050 RPM
• Controller—60-Volt, 150-Amp USB Programmable Kelly Controller
• Charger—60-Volt, 20-Amp Charger that Plugs into a Standard 110-Volt Outlet
• Tires—Kunaź Cross Street Tread, 130/60-10
• Brakes—Front & Rear Dot Hydraulic Disc Brake with Electric Motor Cutoff and Brake Switches (L/R)
• Quick Disconnect Wire Connections
Eflite Blade 400 heli on 3s
