Make your fans bullet proof.
Cartwheels
Make your fans bullet proof. - 05.22.2007, 07:57 PM
Well maybe not bullet proof, but at least R/C tough. I got tired of putting new fans in my conversions only to have them only last 20 minutes before they puke up their internals components. The smaller fans weren't so much of a problem, for me at least, it was the larger size like the 40mm fans were the problem. So I decided to do something about it. Here a couple of things you can do to make your fans tougher.
Here is the most of the stuff your going to need:
Soldering Iron
Small gauge multi strand wire
Electrical grade epoxy or substitute (I used a 3M's part # DP 270) I got this at Mc Master Carr $11.13 http://www.mcmaster.com/
Hand plunger for the epoxy, as it doesn't come with one. I got this at Mc Master Carr also Part # 74695A27 $1.15each
ID:	2950   Click image for larger version
Cartwheels
05.22.2007, 07:59 PM
First pop the internal part of the fan out of the case (pix). Be careful not to break the thin plastic supports on the case backing. What I do is support the case backing with one screwdriver and with another screwdriver push on the bearing ring area shown with the smaller screwdriver.
Cartwheels
05.22.2007, 08:00 PM
I replace the wire. The original wire is a single strand wire and breaks very, very easily. So, once I have the internal part of the fan out I replace it with a small gauge multi strand wire. I would recommend doing this one wire at a time otherwise it is easy to forget which color goes were. So just desolder the old wire and solder in the new wire. I have skipped this step only to have to go back and fix it later.
Cartwheels
05.22.2007, 08:01 PM
Then to permanently keep the fan internals in there place use electrical grade epoxy. I yellowed the area in the pic to apply the epoxy. Then also put a little epoxy on the electrical components that stick up on the green PCB board. keep in mind you don't want epoxy oozing out everywhere because it will lock up the fan. Route the wires back were they go. Then press the fan back together. Set it to dry so that if any epoxy oozes out it doesn't drip on the fan blades (in other words, fan blades up, glue side down).
I have had really good results with doing this and I'm sure you will too!
Name:	9 glue area.JPG
ID:	2954   Click image for larger version
joeling
joeling's Avatar
05.22.2007, 10:01 PM
Hi Cartwheels,
This is a good mod. 1 vote for this to be in sticky.
Regards,
Joe Ling
PS : Noticed the caps. Sell those to the DIY audio crowd
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
Cartwheels
05.23.2007, 02:23 AM
Glad you like it. I'm running about 5 fans all together in different conversions and not one has given me any problems so far. First one I did was about a month ago.
One thing I forgot to mention is that when I'm done I usually cover the back with a piece of electrical tape to keep dirt out of the bearing.
05.23.2007, 09:36 AM
Nice details Cart!
I have never run fans in any R/C before. What fails on them? From the posts above, I assume the hub sperates from the frame? Also, how long do the bearings last in the dusty and harsh offroad environment?
Cartwheels
05.23.2007, 11:27 AM
Yes the hub seperates from the fan then sometimes just hangs there or it can also get completely ripped off.
I have never had a fan stop from dust, but I never had them live this long either. I run in some hot weather so I have the front windshield cut out and sometimes the dust and dirt just pour in. So if they do stop from dust I'll end up finding out! Lol
Procharged5.0
Procharged5.0's Avatar
05.23.2007, 02:03 PM
+1 Vote for it to be a sticky! Nice post!
aqwut
Brushless Heavy Weight....
aqwut's Avatar
06.19.2007, 11:52 PM
very nice.. I did the same to all my 40mm fans.. those fans aren't that cheap either.. :)
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Cartwheels
06.22.2007, 02:46 AM
Here is an update: The glue has been holding very well, but I did have one of my fans break the metal shaft the fan blades spin on. Had to throw it away, no way to fix that! Just goes to show what forces are at work.
One other thing I found out was that when you replace the wire. You want to use really thin gauge wire to solder onto the fan with. Thicker wire can break off the little tab that you solder onto rendering the fan useless.
MetalMan
MetalMan's Avatar
06.23.2007, 12:14 AM
Funny thing is, I haven't had a problem with any fan parts that you modded above. The only thing that breaks/gets damaged on my fans are the blades, where they break off.
Cartwheels
06.23.2007, 09:07 PM
I wish I didn't have problems with mine! Might be the position they are mounted. I have not had problems with smaller fans just the larger ones.
marc993turbo
08.25.2007, 02:37 PM
Hi there from Germany!
I just installed three fans in my savage today to keep controller and engine cool.
I would like to see some pictures of your fan modifications but cannot see them because they don´t appear when i display the thread.
Is this a problem with my account?
Thanks for help.
Marc.
08.25.2007, 03:59 PM
No, your account if fine. The forum was recently restored (was a crash about a month ago) and some things aren't quite working 100% yet.
