RC-Monster G-Maxx
UBEC Smoking -
07.05.2006, 07:22 PM
Why is my UBEC smoking? I am replacing one (that had the same problem). I removed the blk jumper on my 12120, so that is not the problem. Ran w/ reciever pack and it seems fine.
I checked my wires and they seem fine..Plz help...
07.05.2006, 07:28 PM
Maybe faulty ubec? Has it been through any hard damage? You should get a free replacement since it has a 1 year warranty on manufactering defects. Did you say its your second smoked ubec?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
RC-Monster G-Maxx
07.05.2006, 07:36 PM
Yes, I smoked one last week. I think that it has something to do w/ my truck. My throttle starts to act erratically and the UBEC gets hot and starts to melt the white shrink wrap.
I also noticed that the 2 caps (silver ends) on the positive side of my 12120 are not flat, they are pushed out slightly.
07.05.2006, 09:41 PM
EEK! You popped 2 caps on your 12020 than! That results in a hot ubec. You gotta send that thing to mike so he can replace it.
Losi 8ight e
RC-Monster G-Maxx
07.05.2006, 10:05 PM
What would cause the caps to pop? The controller never got hotter than 125.
07.05.2006, 10:25 PM
Well, either the caps were overheated or bad from the start, any water go on them?
Losi 8ight e
07.05.2006, 10:29 PM
Caps also expand from a voltage higher than its rating. They can also expand with reverse polarity, but they usually full pop from that.
07.05.2006, 10:47 PM
I would think that the smoke is from the UBEC grounding out which could also cause the caps to pop or swell. Is it on a aluminum chassis?
RC-Monster G-Maxx
07.06.2006, 02:35 AM
Yes it sits on an al. chassis, but I have plenty of pading and I know that it is not touching.
07.06.2006, 02:27 PM
I had a ubec do the same thing. Do you have a switch in it?
RC-Monster G-Maxx
07.06.2006, 04:47 PM
No switch. What was your solution?
07.06.2006, 04:55 PM
Well, the reason i asked is because when i wired my switch in the last time, i think i had a bad connection after that. I cured everything by replacing the switch, ubec, and redid my connections all over. And now i can go far away and it's smooth runnin. But i took my time on everything and double, then triple checked everything again! Yanked and pulled and inspected each solder joint. I would say some thing with yours is wired wrong, or bad connection somewhere. UBEC are finiky it seems. Oh, and i took it off my chassis all together! I mounted it on the side of my receiver box.
07.06.2006, 06:10 PM
Try to make sure your batteries are not touching the chassis. I did that and smoked ubec and the caps on the esc.
RC-Monster G-Maxx
07.06.2006, 07:07 PM
The batts are not touching and all of my wires are double insulated so it won't touch accidentally.
Today I ran through a pack of batts using a reciever pack and everything worked fine. Maybe it was my soldering, who knows.....but I did get 25-30 runs w/ the first ubec that fried. The second ubec fried within the first 5 minutes of the run.
