Kv And Rpm Limits Of The Wanderer Xl?
SKiTZ
Kv And Rpm Limits Of The Wanderer Xl? - 07.20.2006, 01:25 PM
what is the max rpm of the wanderer xl? what is the kv for it too?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
07.20.2006, 02:16 PM
About 50,000. You should shoot for 30-40k for normal running or else it will overheat. It doesn't matter what kv is used, as long as you use the correct voltage to get there. e.g. 2000 kv needs 15 volts for 30,000 rpm.
Area 52 Ranch Raceway
T.R.C.R.
coolhandcountry
coolhandcountry's Avatar
07.20.2006, 02:38 PM
The kv varies from motor to motor. 7xl is about 2100 and the 12xl is about 1200. That is loaded values.
neweuser
neweuser's Avatar
07.20.2006, 03:28 PM
so take the motor kv x the volts = rpms
Serum
Serum's Avatar
07.20.2006, 06:44 PM
Here is a complete list;
SKiTZ
07.20.2006, 10:03 PM
how about the 9920, the wanderer 8 xl, and a 4000mah 14.8v li-po batttery?
squeeforever
squeeforever's Avatar
07.20.2006, 10:38 PM
That would be a great setup. I would go for something like a Quark 125 if budget allows.
