are these good cvd's
emaxxdriver18
are these good cvd's - 07.09.2006, 12:27 PM
i am thinking of getting these cvd's http://www.rc-monster.com/proddetail...=TBTM01&cat=47 but wanted to see what you guys say i like the fact that they have boots and i will be runnin a 7xl on 12 or 14 cells will those cvd's hold up good with all the torque
coolhandcountry
coolhandcountry's Avatar
07.09.2006, 12:56 PM
Well what size tire you going to run?
The smaller tires with less traction are more likely to let the cvd survive.
The bigger the more pressure is on the cvd.
I never ran them. The probably hold ok. 12 to 14 cells is not to hard on them.
neweuser
neweuser's Avatar
07.09.2006, 02:43 PM
on 12-14 cells you'll be fine. They are jut like the ones i had before my UE's. Never broke them, even with 16 cells.
Serum
Serum's Avatar
07.09.2006, 03:00 PM
I am hearing mixxed stories about these shafts.
One loves them, and one keeps braking them.
Keep in mind that you can't use them with 1/8th diffs, unlike the UE or the MIP cvd's.
neweuser
neweuser's Avatar
07.09.2006, 03:10 PM
i used then 1/8th diffs, but i didn't drive it that hard. As with anything, you get what you pay (said this hundred times at least), and for me, i started off with this or that, in the end, wanted more power and speed so ended getting the other. IMO, get the better or best right off the bat because you will in the end anyway! These will work fine, don't recommend to run with the 1/8 diffs either, but if you don't drive real hard....get MIP's though dude!
civicwil
07.11.2006, 01:15 PM
I wouldn't recommend these at all. If you go to my thread (On the right Track) you'll see what happened to a set of these after only the third jump.
I have the UE's now and have had no issues.
