Brushless power
2f43t4yall
Brushless power - 06.22.2006, 05:14 AM
hey guys, ive just purchaced the front and rear end of a revo to go with the G2R chassis when it arrives. Im having alot of trouble with my emaxx constantly having to upgrade parts to make it strong so it will take the power...will the G2R be the same? What have people broken on them? What is an essential upgrade? what brushless combo would be best for at least 5-10 minute runtimes on 14 cells but would like the option to go up to around 16-18? Ive been told the 9920, 7xl/10xl are a good combo?? How would they be geared/ Is Mod 1 worth it for the revo?
sorry about all the questions, just dont want to make anymore wrong desicions. Thanks in advance.
Cheers Adam
squeeforever
squeeforever's Avatar
06.22.2006, 12:00 PM
No, the G2R won't be like the Maxx. You might break a select few parts if your really tuff on it, but the only thing I've ever broken was a pillowball. And that wouldn't have happened if I didn't have aluminum arms on it.
2f43t4yall
06.22.2006, 02:02 PM
So what brushless set-up do you guys think? minimum 5-10 mins run time nice power, run cool...14 cells but the option to go to more 16-18?
Cheers Adam
squeeforever
06.22.2006, 02:30 PM
I would say a 9XL. Maybe a 10XL.
2f43t4yall
06.22.2006, 02:47 PM
What would the difference be between the 9XL and the 10XL
squeeforever
06.22.2006, 05:03 PM
The 9XL will offer slightly more power but less runtime and visa-versa.
crazyjr
crazyjr's Avatar
06.22.2006, 09:12 PM
Squee's right, the G2R is practically unbreakable (watch, i said that and will break something at the race tomorrow, haha)I haven't broke anything yet. I'm running a Novak HV brushless and can make ten minutes on cheap 3300's
2f43t4yall
06.23.2006, 11:03 AM
How long run times should i expect from the 10XL and 9XL on IB4200's?
squeeforever
06.23.2006, 11:18 AM
9XL, at least 20+ minutes HARD running and close to 30 with the 10XL.
2f43t4yall
06.23.2006, 11:20 AM
i think ill go with the 9XL then...would the 9920 be ok? What speeds would i get on 14 cells and on 18 cells?
squeeforever
06.23.2006, 11:27 AM
14, probably around 40ish, with 18, I would say 55+ probably. As for speedos, I would personally go for the Quark 125.
2f43t4yall
06.23.2006, 11:29 AM
what are the advantages of the 125 over the 9920?
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
07.28.2006, 07:26 AM
I am running a 7xl with a Quark 125 and it gets very hot very quickly. The 7xl is hotter than the 9 or 10 but you will still need a fan or heat sink or in my case both if you are going to race it. The Quark is a very nice smooth as butter controller but the case just doesnt dissapate enough heat (no fins?)to keep it cool. If you are just bashing or running 5 minute heats you can get away with it, maybe.
If you use Lipos it will add even more heat (high amps 60-80 vs 30-40 for nihm)
Never fight an ugly man..... he has nothing to loose
Procharged5.0
Procharged5.0's Avatar
07.28.2006, 09:11 AM
Aside from the heat of the Quark, how do you like it? Does it program ok? Can you program by pc or just by the button? Does the reverse function ok? I'd really like to get an honest opinion before I buy. I'm looking for EVX behavior but with a brushless system.
Sylvester
Sylvester's Avatar
06.23.2006, 11:35 AM
The 125 should be smoother and run cooler, and it just looks soo darn sexy in the case its in:) *Edit* I wouldnt run 18 cells in a revo, unless you can find some super stiff springs for it!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
