rustler q,s ??
speedy
rustler q,s ?? - 09.01.2006, 10:25 AM
Hi !
I'd like to know if anybody here's got a bl rutler and what setup's you've have:027:
And doe's anyone have a mambamax 5700 motor in there rusty ? if so what gearing and pack's do you run ?
stampy
stampy's Avatar
09.01.2006, 10:57 AM
Ive got one :028: its not mamba powered but i like it. lenher xl3600 quark 80b on 3s 3700 hyperion lipo. gearing im still playing around with right now im running 12 60 (32p) and its to low for me i think right around 13 60 should be about right when i get some mashers on it:018:
rcjmaxx
09.01.2006, 12:57 PM
Ive got a Rustler with a Feigao 8L,9918 and 4 cell lipo.For topspeed,54T spur and 22T pinion 32 pitch gears with HPI Geolander tires.For onroad handleing, 20T pinion and Proline Road Rage.
speedy
09.01.2006, 01:52 PM
what's your gear ratio in 48pich gears ?
rcjmaxx
09.01.2006, 02:52 PM
I have no idea.When I got this as a roller off of Ebay it had no gears and all I had was my former Emaxx stuff.It worked so I stuck with it.
MetalMan
MetalMan's Avatar
09.01.2006, 06:44 PM
Highly custom Rustler with:
-Custom Garolite G10 chassis
-FLM front arms/front bulkhead/tranny case (just broke the alu. bulkhead the other day)
-Aluminum idler
-Blue Bird BMS-620mg servo
-Nitro Rustler front steering setup with Powerline aluminum c-hubs
-4-tec aluminum rear axle carriers
-Dogbone conversion using HPI parts
-Fiberglass shock tower that broke when I broke the FLM aluminum bulkhead
-Modified steering bellcranks
-Custom 3-piece rear shock tower (aluminum base plate, aluminum angle for attaching base plate and tower, and 1/4" polycarbonate tower)
-Ofna 1/8 Super Shocks on the rear, Duratrax Overdrive ST shocks with soft springs on the front
-HPI Geolandar tires on the Traxxas lite wheels
Power system:
-Mamba Max 4600 system
-Electric Power 4s 6600mah 8C LiPo battery
-16/87 gearing (still playing with it though)
It's fast, but I've been getting bad range, so I can't say how fast it can go.
