Fried My 9920!!!
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
Fried My 9920!!! - 12.23.2006, 06:01 PM
basicly heres wut happened. I altered my lisaver so that the the wires woudl only connect to one batt, instead of both of them together. The guy who i bought the lisaver form said thats why it went in reverse instead of stopping the car. When i pluged in one of the packs, a puff of smoke came out of the esc. I instantly remove it and looked at teh controller. I took some pics of it. Seems liek the brown wiere was loose, u can see it popping from teh side. That is what i beleive coudl have been it. Or it coudl have been cuz i put the lisaver to one of teh batts. Heres a diagram
____(LiSAVER)__
l
ESC-l____(lipo)
  Send a message via AIM to nbcaznmaster
nbcaznmaster
12.23.2006, 06:19 PM
Heres the pic, Is it savable? Could i just resolder the wire back on and have it running again? Please tell my my esc isnt fried! This is bullsh**! Outta my 4 brushless escs i ever had, 2 of them broke! WTF! :035: Its my freaking 2nd broken 9920!
nbcaznmaster
12.23.2006, 07:05 PM
Come on guyS! is it salvagable? if not, i wanan grab that 9920 deal from miek before its to late
12.23.2006, 08:41 PM
It's really hard to say. Usually, when there is a puff of smoke and lifted traces like in your pic, it usually takes out something else and it's difficult to determine what unless you know how to troubleshoot electronics.
Wow, nbcaz, you really have the worst luck!
Sylvester
Sylvester's Avatar
12.23.2006, 08:50 PM
That sucks man, IMO take advantage of the holiday specials. I see one solution to your bad luck ; TAKE YOUR TIME! Every time i see you post your either in a rush or you just want it to work. If you take some time and do things right first ; you will have a happy smile on your face. Im not saying this caused you 9920 to go up in smokes but ive seen a bit of things you've rushed. For instance ; You cardboard battery holders in your revo ; that was humerous, i have to say :) ;)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
I Can Top That
Mark Fradkin
Rad Frad
Cool I Can Top That - 12.23.2006, 09:54 PM
I WOULD HAVE BEEN BETTER OF JUST DRIVING MY TRUCK INTO THE OCEAN.
then only the electronics would be shot
I was ripping sand runs at the beach today when I SLAMMED into a unseen small concrete small devistating sorta hidden concrete block about 40 yards away. SEVERE IMPACT. 20 to 30 MPH EST
DAMAGE
New Era ext CHASSIS bent mid length
TRAXXAS SHIFT SERVO DESTROYED
EXPENSIVE STEERING SERVO DESTROYED
2 5S APACHEE PACKS / PUNCTURED
GORILLA STRAPS BOTH TORN
SCREWS SHIERED ONE GREAT ASSEMBLY FRONT BULK
QUARK 125B DOES NOT TURN ON
FIEGO 9XL BOTH ENDS CAME OFF BUT I think it will still work
CAN ANTONE--TOP THAT just GOT the car ripping too
Procharged5.0
Procharged5.0's Avatar
12.26.2006, 05:49 PM
DAMAGE
You must post pictures! BTW sorry to hear about the wreck. It's a bummer!
Nick
COOKIES!
Nick's Avatar
12.23.2006, 09:58 PM
Doesn't look to bad to me. Just lose contacts. If your good (and I mean good!) at soldering, try removing the wires and seeing how bad the damage is, then solder them back on indiviually and seperate.
~ Nick.
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
12.23.2006, 10:13 PM
take a old DRY toothbrush and gently clean that area off and see what it looks like.....maybe something got in there and shorted across everything....
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
coolhandcountry
coolhandcountry's Avatar
12.23.2006, 11:11 PM
The reason for reverse was it was a plane lisaver.
The reason for the smoke was you hooked the lisaver up wrong.
I hope this helps.
I think you may want to invest in esc while sale is on.
sjcrss
sjcrss's Avatar
12.23.2006, 11:16 PM
Hey, you could clean up the area...and being extra carefull...you could resolder the black wire on...and change the wiring back to the way it was on the lipo saver and give a shot again....it wouldn't hurt to try
Bl E-REVO
Quark 125b
((2s2p)(4s)
nbcaznmaster
12.23.2006, 11:36 PM
Well, thats the way they sell the lisavers on RCM, with the little deans extention. Thats how i set mine up. Before i had one RED wire on one pack, adn the black wire on the other.
sjcrss
sjcrss's Avatar
12.24.2006, 09:01 AM
so with the little deans ext on it...it worked fine.....but when you wired a red wire to red wire and like wise with the black....it fried....hmmm
i cut the connector of mine as well & wired it in that way to......now im a little worried
Bl E-REVO
Quark 125b
((2s2p)(4s)
sjcrss
sjcrss's Avatar
12.24.2006, 09:09 AM
I just tested mine with it wired ....without the deans connector....ans the red wire goint to the + battery wire off of controler and the black giong to the -on the controller as well...and it all worked just fine...no problems at all.....so are you sure you didn't wire it on wrong or something?
Bl E-REVO
Quark 125b
((2s2p)(4s)
Sylvester
Sylvester's Avatar
12.24.2006, 10:05 AM
That shouldnt have been the problem, since i doubt the deans connector would lose some kind of interference, and Shayne's (sjcrss) works. I bet you put the wrong polarities together.
Losi 8ight e
