Opinions on the UBEC
Skelbow
Skelbow's Avatar
Opinions on the UBEC - 10.02.2006, 06:56 PM
I'm blowing all the dust off my 9920/7XL Twin Force and I am going to rewire it all.
From what I remember, it had radio problems, and I think it was because of my UBEC I had in it..
SO, do people actually use these UBECs? or does everyone seem to have problems with them? Am I better off just using a receiver pack?
Thanks.
  Send a message via MSN to Skelbow
10.02.2006, 08:39 PM
I use the UBEC in my BL Revo with absolutely no glitching whatsoever. I did install a 1000uF capacitor in the aux slot in the Rx to help filter any noise on the power line though, and I'm using a Spektrum DX3. It also helps to keep the Rx away from the motor wires. I also wouldn't install the UBEC right on/next to the Rx just in case the UBEC emits a little noise (even though the specs say it doesn't emit appreciable noise).
danverz
10.03.2006, 10:12 AM
I heard a lot about burned/melted UBEC.
Personally I prefer MedusaProducts Potencia BECs (they are also coming out with a 6A
version).
I use it on electric helis, my monster, and some times ago on my touring and on my losi
buggy. I never experienced problems with Potencia BECs. And first over all, I think they
are really more reliable than the UBEC ones.
I'm saying this also for its capacity to keep quite costant the tension when the current draw
is jumping a lot.
Ciao,
Daniele
Cartwheels
10.03.2006, 04:56 PM
I've owned a few UBEC's. I've never experienced any problems with them. You could try a reciever pack to see if the UBEC is the problem. Is your antenna mounted to an aluminum chassis or next to any wires?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
10.29.2006, 10:32 PM
good point.....I've never fried a UBEC, but make sure the antenna is away from it as well...and make sure it isn't attached to a metal chassis....other than that you should be good....Ebay has some for about $15.00 and mike has some on here I think for about $30.00 as well...not sure
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
crazyjr
crazyjr's Avatar
10.29.2006, 10:54 PM
I'm using a plastic antenna mount on alumnium chassis would that be enough isolation?
squeeforever
squeeforever's Avatar
10.29.2006, 11:35 PM
I would guess so...
natrix
10.30.2006, 11:54 AM
I have no problems with my UBEC. I have it inside a small plastic project box to protect it from the elements and my RX is a spektrum sr3000. They are within 2.5 inches of each other. No glitching whatsoever.
vette1
vette1
vette1's Avatar
10.30.2006, 12:28 PM
I blew up my UBEC but it was becasue I shorted the batteries against the chassis not because the UBEC was at fault. I replaced it and I haven't had a problem since. At least with that. I have other problems. :007:
I'm crazy and I'm not afraid to talk about it.
sjcrss
sjcrss's Avatar
10.30.2006, 02:55 PM
My Ubec is several mm away from everything else...& I have no issues as well...
Bl E-REVO
Quark 125b
((2s2p)(4s)
BitHed
10.30.2006, 08:45 PM
...i guees this gets asked alot and I am sure there is a FAQ or a sticky that you will all direct me to but what is a UBEC and what des it do? Should I have one? Does it come in pretty colours? :040:
10.30.2006, 09:34 PM
BEC=Battery Eliminator Circuit. The U in UBEC stands for Ultimate IIRC.
It's just a voltage regulator that turns the main battery voltage into a lower voltage (5v or 6v typically) that your receiver and servos can handle. Without this regulator, you'd have to use a seperate 4 or 5 cell battery pack, which adds weight and something else to charge.
You can click here for more info, but it's probably more data than you need...
