Watts & Amps
Nick
COOKIES!
Nick's Avatar
Watts & Amps - 11.12.2006, 08:11 PM
How do you work out how many Watts and Amps your motor produces/draws? Is there a formula for this?
~ Nick.
11.12.2006, 08:50 PM
I'm sure there is a formula, but since the motor is an AC motor and is therefore dependent on frequency, inductance, and load, it would be quite complex. Much easier to measure the current and voltage drawn from the batteries and do your calculation there. Even then, the power drawn will change dramatically based on the acceleration. A device like the eagletree systems unit takes voltage and current samples every so often (100ms IIRC) and then you can upload that to a PC to get a graph of the power usage.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.13.2006, 01:32 AM
Would the feigao power analyzer do the same?...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
11.13.2006, 02:07 AM
Not sure. Do you have a link to the product description?
Basically, you want a device that can measure both voltage and current samples in realtime.
Serum
Serum's Avatar
11.13.2006, 02:42 AM
Eageltree micro logger.
aqwut
aqwut's Avatar
11.13.2006, 11:35 AM
http://home.comcast.net/~truerc/Charge/chargers.htm
it's a feigao 100 amps power analyzer... it was cheap that's why I got it....
how you liking your eagletree... I wonder if this will die if I use more than 100 amps?..
Serum
Serum's Avatar
11.13.2006, 01:40 PM
130A peaks are not a problem.
aqwut
aqwut's Avatar
11.13.2006, 06:30 PM
ah.. that's cool then.... but you like the eagle tree better...
