Single Speed
rustnpede
RC-Monster Parking Attendant
rustnpede's Avatar
Single Speed - 11.16.2006, 05:31 PM
When slowly I turn the shafts on my single speed the action is kind of rachety, but when I turn it faster it smoothens out. Is this normal? I took apart and reassembled it several times but get the same results. I have the steel idler.
squeeforever
squeeforever's Avatar
11.16.2006, 05:56 PM
Did you look at all the teeth on the gears?
rustnpede
rustnpede's Avatar
11.17.2006, 03:27 AM
Pulled it appart again and the teeth on each gear looks clean and uniform. With the plate pressed against the case the gears are smooth, but once I tighten the screws thats when the action is rough.
Originally Posted by jhautz
Don't turn it slow then. :005:
Oh dont worry, once I get this thing up and runing I dont plan on going easy on the tranny.:cool:
Darren
11.17.2006, 05:52 AM
Could be excess shims preloading the bearings?
crazyjr
crazyjr's Avatar
11.16.2006, 07:25 PM
I got a similar thing in mine with the plastic idler, it should be ok
jhautz
jhautz's Avatar
11.16.2006, 07:29 PM
Don't turn it slow then.:005:
Kidding.:018:
to make it...
or break it...
Silent...But Deadly
