Esc
E-Maxx King
Esc - 11.20.2006, 01:26 AM
Would this ESC be relieable with a 9l or 9xl on 14 cells?
MetalMan
MetalMan's Avatar
11.20.2006, 01:41 AM
Did you mean to post a link?
E-Maxx King
11.20.2006, 04:37 PM
No, just aking If this setup is reliable!
neweuser
neweuser's Avatar
11.20.2006, 05:17 PM
I think his question is the MM esc, if so, yes, it'll do fine with a 9xl on 14 cells. I believe crazyjr is doing it now. Personally, I would not run a 9L in an Emaxx when the xl is a better option. IMO
crazyjr
crazyjr's Avatar
11.20.2006, 10:18 PM
That would be me, yeah its a good setup. I'm running it with 12 cells , but might be going to 4s lipo's soon. Speed wise it runs great on a track and bumpy surfaces, but on smoother surfaces it might be a little slow. If you want more speed, go for the 8XL, there is another (i think Finnster, has this combo with 14 -16 cells NIMH). The only thing you need to do is to remove the middle wire from the esc plug and use a reciever pack or UBEC, I also changed the mamba plugs to 5.5mm to work with the wanderer i got.
E-Maxx King
11.20.2006, 05:52 PM
Sounds Good! Could you post a vid with this setup?
neweuser
neweuser's Avatar
11.20.2006, 05:58 PM
I don't own the actual system, and the guy that does may not have the capability to do so. But it works well from what I've heard, decently fast.
