I moved the 9920 to my sons Emaxx running 3S Lipo and a Mamba Max 5700 motor. It's cutting out like crazy at full throttle. It never did this running my LST2 on 5S.
What the heck?
Mine:
2007 Grizzly 700 EPS EFI
Sons:
BL E-Maxx
4S MA 4000 Lipo/MM ESC
Feigao 9XL 22/54 gearing
Gmaxx single speed
Probably you're having the same problem as me with the 149.18 controller with 3s. The MambaMax motor in a Maxx?!!!! Tooooo small!
You should atleast get a Wanderer L size motor with 4s lipos if you want to eliminate the abnormal stuttering.
Also, if you're not using an external BEC, because I have a feeling that your controller's BEC is not working right, it might be the reason why its stuttering like that.
Nice to meet you!
