Will there be cooling issues
GorillaMaxx360
GorillaMaxx360's Avatar
Smile Will there be cooling issues - 12.21.2006, 07:30 PM
I was just going over my buildup of my next project and i was going through possable problems that could happen and i was wondering if heating of the motor would be one of them. I will be running slipperential, 7xl, quark with one 2 fans, rc monster heatsink for esc, external ubec, 4s lipo a 20t pinion, standard size dish 17mm wheels and crimefighter tires and a 36t spur. Do you think i will have heating issues. if so what can i do to fix this. Also if there should not be heating problems is there anything i can do to help the motor run cooler just to be safe. Also the rc monster heatsink for the motor does this fit the 7xl and will this help with the cooling issues. (if this helps my truck will be using a combonation of graphite, titanium, and a small anount of aluminum like the combo bulks and alu diff cups and thats all that will be aluminum so i think the truck will be slightly lighter than stock but not sure.) Thanks a lot :)
