Well if it has burn the slipper pegs up.
They will need to be placed.
I noticed the stock spring on slipper is weak.
I picked up on for a mgt and put on.
It held up so much better.
Well, I figure whatever I do I might as well do it brushless proof cause there is no doubt that when the MM is available I will be getting one. So, if your suggestion is up to the task I will consider it, otherwise I would assume get something else, like the suggested strobe.
My friend has a t maxx and he mentioned something about a carbon slipper part that was fairly cheap. Know anything about this?. Are the t/e maxx slippers the same?
