slipperentials
turbo4
turbo4's Avatar
slipperentials - 01.31.2007, 10:24 PM
are they ready yet. Also I believe Procharged was working on a slipper, any word on that one?
Serum
Serum's Avatar
02.01.2007, 07:01 AM
Yes, check the store, under rc-monster parts, you´ll see them. Procharged has got a slipper, not a differential. Mike is currently working on a slipper-diff in one.. it should be the bomb IMO. Nice for buggies and truggies!
turbo4
turbo4's Avatar
02.01.2007, 12:33 PM
The slipper diffs are what I was asking about, not the transmissions. Anyway, my stock emaxx slipper is shot. What are my choices and which would be the best for the stock chassis?
As far as the RC monster store, whats the deal with everthing out of stock, its been like that for a while.
thanks
Procharged5.0
Procharged5.0's Avatar
02.01.2007, 12:38 PM
If you are running a stock e-maxx trans then my slipper will do you alot of good. Look for the post from the other day detailing the product & for pics (LINK BELOW). Other choices are the Robinson Racing Products slipper (I've used it with success) and the Strobe sold here at RC-M.
http://www.rc-monster.com/forum/showthread.php?t=5425
Name:	SLIPPER IMAGE.GIF
turbo4
turbo4's Avatar
02.01.2007, 12:53 PM
Looks good, what is the size of the spur? What kind of price? I can't read the writing its to small. Thanks.
neweuser
neweuser's Avatar
02.01.2007, 01:00 PM
click on the picture and it will blow up for you.
turbo4
turbo4's Avatar
02.01.2007, 01:21 PM
Yes, I can read it now. I was trying to read the one you posted in the link, that one will not maximize enough.
neweuser
neweuser's Avatar
02.01.2007, 01:23 PM
Glad you got it! Very good info there.
Procharged5.0
02.01.2007, 12:58 PM
Try clicking on the image and maximizing your window. It should be easily readable.
Spur choices are 48t/49t/50t/51t/52t
Price has not been set yet but will be soon. Expect $60 for the Standard Version and $85 - $90 for the PRO version.
Spurs
Kiwi E-Maxx
Spurs - 02.01.2007, 06:44 PM
Hi
What pitch will these Spurs be? 32 or Mod?
Spurs
Kiwi E-Maxx
Spurs - 02.01.2007, 06:46 PM
Hi
What pitch will these Spurs be? 32 or Mod? Also one more question , what advantage in terms of performance will these be over the RRP Dbl disc setup.. I'm assume torque control as traxxas states with their Revo and Maxx 3.3 vehicles..
Cheers
Procharged5.0
02.01.2007, 06:49 PM
Originally Posted by Kiwi E-Maxx
Hi
Cheers
Torque control, stronger input shaft, stronger gear to shaft attachment, better gear selection, and with the PRO model lower friction & wear, stronger spur, cooler operation.
Hi
Kiwi E-Maxx
Hi - 02.01.2007, 06:54 PM
Thanks very much,
I'm sold if there is a 1/8 bore Mod1 10 tooth Pinion. Don't think Mike sells them.
Procharged5.0
02.01.2007, 06:47 PM
Hi Kiwi. Welcome to the RC-Monster forums.
The Spur gear will be MOD-1 to match up with most brushless motor pinions.
I do not have a 32P gear available at this time but MOD1 pinions are available in 1/8", 4mm, and 5mm bores.
neweuser
neweuser's Avatar
02.01.2007, 06:57 PM
Mike can get one or make one though! :)
