It mounts through the 4 M6 threaded holes when using
If i still own a gorilla, i would be able to make mounting patterns for it, but I don't own one anymore.
Do you guys know how the tmaxx braking system works? It's a little hard to explain w/o demontration. but i'll try and take a stab at it:
this goes through the center hole on the top side (top side is illustrated in the 2nd and 3rd pic). The extension of the hole covers the majority of this part for added support.
The device will use an extended version of
This gold nut. The gold nut will be inserted into the large middle hole of the 1st picture
A hex like
this will be placed over your cvd cup (i use the supermaxx one), then
this will be place over the hex.
The two brake pads shown
here will be screwed into the two m3 holes shown in the first picture
When
this spins (from the servo), the gold nut in
This picture gets pushed out. Applying force to the brake pads, which cramp the brake disc and slow the car down.
It will all come together once I buy it. The thing about buying these custom parts is that it costs $135 for one, but then to add on another one it is only $10...so i will probably order 5 and see if anyone wants them.
