maxamps 4s lipo good?
Looneybin
maxamps 4s lipo good? - 04.16.2007, 01:54 PM
http://www.maxamps.com/proddetail.ph...48-Pack&cat=13
is this batt good enough for a basher revo. its what i can afford right now and i want to get my revo up and running finnally
neweuser
neweuser's Avatar
04.16.2007, 02:00 PM
Depends on the motor and gearing, but I would get the 8000mah instead. I run the 4s 8000 in my maxx
AAngel
04.16.2007, 02:01 PM
Are you going to be running a single battery pack or two in series? Anyway, the 5K cells are supposed to be the latest hot thing at maxamps and they packs/cells are usually very good bang for the buck. What setup are you running?
Looneybin
04.16.2007, 02:05 PM
8xl/mamba maxx/stock tranny locked in 2nd. i would really like to run one pack. thanks for the quick response.
AAngel
04.16.2007, 02:10 PM
I haven't tried the newer "copper" tab cells. I do have a couple of the pre-copper tab packs and with an 8XL, we were able to heat the 8Ah packs up pretty good in an 8ight. Your revo should weigh about as much as the 1/8 scale buggy. I'd go with the 8Ah pack(s). They can handle more current draw.
MetalMan
MetalMan's Avatar
04.16.2007, 04:44 PM
I'm using a Maxamps 4s 5000mah pack in my Hyper 8 right now. So far I've only done street driving (with Road Rages that are quickly going bald), but it seems to be quite a powerful battery. Best of all, the hottest cell (one that was covered up) has not exceeded 100 deg. F.
bdebde
That's All Folks!
bdebde's Avatar
04.17.2007, 12:02 AM
Those the new copper tab cells?
MetalMan
MetalMan's Avatar
04.17.2007, 12:06 AM
They are supposed to be.
bdebde
That's All Folks!
bdebde's Avatar
04.17.2007, 12:40 AM
Guess I better try one!
Looneybin
04.26.2007, 01:27 PM
this will mainly see parking lot assphalt, gravel driveway, occasional track session. i want to try the 4s 5000mah because i can afford the thing and i want the conveinence of one batt to worry about. thanks. i would hate to sell this thing just because i don't want to deal with the battery issues but maybe a bl stampede or something would be better for a beginner. oh well i am going to go with the 5mah and let yall know if it doesn't work out i may post this thing up for one of you to get your hands on.
bdebde
That's All Folks!
bdebde's Avatar
04.26.2007, 03:26 PM
got a couple runs on my new 4s maxamps 5000HV, seems to be a decent batt, geared 14/46 with 7XL gets it about 100* or so, perfect.
Revo_crazy231
Devin
05.06.2007, 09:53 PM
not trying to thread jack but do u have the choice of running 1 pack or 2 or is there diffrent setops i plan on gettin a mm w/ an 8xl but if i get the 7.4v lipo maxxamps 8000mAH should i get one or two????
i want good speed and long runtimes if possible
thanks and again sry im not trying to take over your thread
  Send a message via AIM to Revo_crazy231
bdebde
That's All Folks!
bdebde's Avatar
05.07.2007, 10:55 AM
you will need to use 2 7.4v batts in series for the 8XL or you can use one 14.8v pack.
Revo_crazy231
Devin
05.07.2007, 07:08 PM
cool, thanks
Trick440
05.07.2007, 08:52 PM
What kind of runtimes are you guys getting off these batteries?
