Would it work
Maxxman
Would it work - 05.16.2007, 02:08 PM
hi guys great forum
just wondered what is the difference between the
BK marine 9920
and
BK 9920
except for the cooling tubes and aluminium heatsink that sticks out the sides.
Just wondered because Chris from fine design sent me one of the BK marine ones instead of a regular one. And as i am in England and bought it in about january, i doubt he would swap it or refund and wondered if it would work in an e-maxx if i removed the tubes.
Serum
Serum's Avatar
05.16.2007, 02:27 PM
the marine uses different software. Not suited for slowing down a car. You need car-software on that controller if you want to use the motor-brake.
Maxxman
05.16.2007, 02:35 PM
Thanks serum
what is a motor brake? is it when the Motor is used to slow down the vehicle?
Not totally new to brushless. Done a lot of reading but i haven't owened one, will do soon as i did buy a Quark 125 and 8XL a few days ago for the e-maxx.
I guess that i'll just try to sell it.
Serum
Serum's Avatar
05.16.2007, 02:39 PM
You can either use a mechanical brake or a motor brake;
the motor brake will indeed slow the vehicle down by using the motor, a mechanical brake slows it down the traditional nitro way.. :)
Maxxman
05.16.2007, 02:57 PM
ok thanks
i thought so but wasn't totally sure.
also if i were to use a mechanical brake i would have to make it or get someone to do it for me right.
Serum
Serum's Avatar
05.16.2007, 02:59 PM
Depends; if you are converting a nitro vehicle to brushless, you can use the stock disk brake. You can check your warrior if it uses carsoftware or not.
Maxxman
05.16.2007, 03:07 PM
electric only for me now.
have savage but i just can't get the hang of nitro or the amount of money needed. No job that doesn't help much suprising huh.
