Mamba Max and Spektrum receiver programing
Cajun
Mamba Max and Spektrum receiver programing - 05.05.2007, 07:25 PM
Ok, so I've been thinking about how to program my ESC and receiver and I'm stumped.
Which do I do first? Do I set everything up then turn on the power at the ESC, program the reciever, then the ESC? Or is it the other way round? :032:
In my mind it makes sense to do the receiver first, but I thought I would ask you guys to verify that for me.
Thanks!
jhautz
jhautz's Avatar
05.05.2007, 07:30 PM
reciever first. Then ESC.
The ESC needs to know where the center and end points of the thottle are to program correctly. If you program the ESC first then the reciever the center and end points of the throttle could change and effect the performance of the MM.
to make it...
or break it...
Silent...But Deadly
Cajun
05.05.2007, 08:14 PM
Cool, thanks!
BP-Revo
BMW M Power!
BP-Revo's Avatar
05.06.2007, 01:27 AM
If possible, use a receiver pack to lock in your Spektrum. It should help prevent any mishaps.
However, the Mamba should be fine, as it has a programmed safety where it must detect neutral before it arms.
Cajun
05.06.2007, 07:10 AM
I can do that, I have my stock Revo receiver pack. I'll charge it up and use it for the programming. Thanks for the tip.
t-maxxracer32
t-maxxracer32's Avatar
06.02.2007, 03:43 PM
how do you program your esc?
sorry to bring back this thread but im trying to connect my mamba to my spektrum and i could not figure it out
thanks
skellyo
skellyo's Avatar
06.02.2007, 04:43 PM
Use the MM for power to your Spektrum Rx for binding it
Once you've bound your Rx to the Tx, turn off the MM
Turn on the MM, go full throttle till you hear 4 beeps, then full reverse until 4 beeps and then neutral until 4 beeps
Turn off the MM, turn back on and enjoy
I just did this with mine yesterday...piece of cake
t-maxxracer32
06.02.2007, 05:57 PM
kk which slot does the mm go into? the bat/tel spot?
06.02.2007, 06:05 PM
Throttle slot. How else is the ESC gonna know how fast you wanna go. :)
