CC Bec anyone?
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
CC Bec anyone? - 09.14.2007, 05:40 AM
Has any one used one of these yet? I have read threads about them but not one using one yet. I need a BEC soon and Mike is "out of stock" with no reply yet of when he will get some in. (Mikes super busy that why I have not gotten a reply yet.) It looks good, priced right and I like my MM already. Any thoughts?
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
09.14.2007, 10:59 AM
hmmmm....looks good. maybe mr. john holmes will chime in...he's quoted on castle's web page for testing.
Eflite Blade 400 heli on 3s
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.14.2007, 11:28 AM
Looks like somebody messed up when making that "critical" connection diagram.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
09.14.2007, 11:40 AM
Yeah, they say to never hook up the ( - ) BEC lead to the "bridge" ( - ) battery connector, but then the arrow points to the wrong ( - ) lead.
6s (25v) max input seems a bit on the low side though, especially with some of the HV systems out there now. I would think a solid 10s capability would be better.
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
09.14.2007, 06:19 PM
Seems to me that the unit is mainly aimed at crawlers, which don't use super-high voltage setups (hence the massive amp rating for multiple servos). From what I've heard tho, it's a hardy little thing which does its job well.
MetalMan
MetalMan's Avatar
09.15.2007, 12:26 AM
The CCBEC does work VERY well, and aside from the lower voltage, is definitely the best of its class. The only problem right now is actually obtaining it...
Hickoryhead
RC Wanna BE
09.15.2007, 07:44 AM
CC is the only place I can find it at. If this is to low for power then what should I look for? Anything to look for? Mike is out of stock like I said but I need one soon.
kulangflow
Never Fast Enough
kulangflow's Avatar
09.16.2007, 06:18 AM
Originally Posted by Hickoryhead View Post
CC is the only place I can find it at.... Mike is out of stock like I said but I need one soon.
CC BEC at Holmes Hobbies
It should be available from John Holmes "in September", so that should be pretty soon at his point. PM him to find out.
ClodMaxx
ClodMaxx's Avatar
09.16.2007, 11:00 AM
i just found out that castle is behind on all of their products (i'm getting a 2nd MM esc for my crawler, as well as the BEC for my SM) and should be in at the end of the month. i'm not holding my breath though...
Patrick
Patrick's Avatar
09.15.2007, 07:48 AM
If you don't plan on using more than 6s then the CC one should be ok.
sapper_triple6
Student of RC-Monster University
sapper_triple6's Avatar
09.16.2007, 08:06 PM
here you can get the one Mike sells.
http://www.koolflightsystems.com/ultimatebec.htm
  Send a message via Yahoo to sapper_triple6
gasshead
j-womp
gasshead's Avatar
09.16.2007, 09:22 PM
i got one, but still need to get another castle link to program it. its crazy small and should do quite nicley on my revo with only one servo and 3 fans
  Send a message via AIM to gasshead
BitHed
09.18.2007, 03:20 AM
..i have one enroute from Kansas to Japan but the shipping addres got 'muddled' and it looks like it might actually bounce back to CC and then have to be re-shipped :( Bummer...
magudaman
09.26.2007, 03:24 PM
I got mine from the LHS and it works great so far. I did some testing with the stock voltage setting at 5.1v and took it up to 6.5 amps and the voltage drooped down to 4.5v with 18.6v input. The unit from my calculations was still something like 91% efficient. My LHS has a castle link for customers so I had them boost it up to 6.4v for my emaxx, I am running 3 fans and 144oz servo.
THE ONLY THINK I DON'T LIKE: is their thin output wire, it like 24-26ga and 1 foot long. Most of that voltage loss at 6.5 amps is probably in the wire.
BitHed
09.26.2007, 11:50 PM
..yay! :D Mine has arrived and fitting it up...Have to agree with Magudaman though...prettty whimpy wires...would it be worth changing them or too much hassle?
