What kind of LiPos and brushless ?
E-Revolution
What kind of LiPos and brushless ? - 09.07.2007, 04:32 AM
I am looking new electric components to my E-Revo, now I have MGM 16016 Hydro ESC, BK Wanderer 8XL motor and MaxAmps 7.4v (100A Constant) 10 000mAh LiPos ( total 14.8v 4s2p) , but now I want more power, and my LiPos are little too big packs
What kind of LiPos and brushless setup is good for my car if I want go fastern than now? Now my car is going like 45mph , maybe 6s LiPos and neu 1515 1y or Lehner 1950 or 2230 is good setup ? Lehner 2230 need new kind of motormount but that is not problem. I use E-Maxx transmission. I am looking MGM 16024 too
Here is some Lipos (2 pack 11.1v LiPos 8k ) what i am looking:
http://maxamps.com/products.php?cat=45
and wires for 3s to 6s:
https://www.unitedhobbies.com/UNITED...idProduct=2156
good LiPos and wires ? Thanks for answers !
- E-Revolution .
09.07.2007, 06:21 AM
Sounds good - What do you do with your old packs?
E-Revolution
09.07.2007, 06:24 AM
I will sell them.
E-Revolution
09.13.2007, 09:47 AM
What you peoples like this setup ? High voltages
E-Revolution
09.27.2007, 09:04 AM
I have been take TMM 16018-3 Car / Boat EXPERT+ ESC, this is hyrdo version with double wiring and 2 active coolers, I taked USBCOM+ too. Im waiting shipment.
Now I am thinking what LiPos I take. Its 6s LiPos bad choise if I run with e-maxx transmission and maybe with BK wanderer 8XL or NEU 1515 1y ? Too much power ? Im interested how much its run, I dont know, what you peoples say for that? No money limit, I can buy also Lehner LMT motor if needed, but I need more information if I am taking Lehner.
I had 4s LiPos and BK Wanderer 6XL and it runs like cannonball, but it was very hot setup ( warm controller and motor, near overheat ) .
Thanks for answers, I will take pictures when my controller and other stuffs come
E-Revolution
09.29.2007, 05:51 AM
Need help with motor and LiPo selection
Patrick
Patrick's Avatar
09.29.2007, 07:45 AM
I run a neu 1515 2.5d (1700kv) on 5s in my e-maxx for racing and a bit of bashing (mainly driving around at full speed on grass). It has a fair bit of power, and you can play with gearing without really affecting anything. I recently got a 6s 4900mah 25C flightpower pack and I've tested my car with that pack twice so far doing mainly high speed runs on grass again. Very fast and powerful and temps of everything was pretty low (motor's only ever warm).
So if you want a powerful motor for 6s my vote is for the 1515 2.5d. The 8xl and 1515 1y (2200kv) will have more rpm so you'll probably be able to get them going faster, but they'll draw a lot of power and temps could be an issue if doing any more than a couple of high speed passes (especially with the 8xl).
For the batteries, what sort of mah packs do you want?
If you only want around 5000mah I say get flightpower packs (4900's are 143mm long and 44mm wide, and the 5000's are 167mm by 48mm, but they are a little bit lower. So depends what fits your car best)
If you want 8000mah then probably max amp packs, but my 10c 8000mah truerc packs do pretty well in 5s. The newer 15c packs should be a bit better, but I haven't heard much about them yet.
E-Revolution
09.29.2007, 11:34 AM
Thanks for answers man ! That motor looks good, maybe I buy that one. I am looking DualSky 5000mAh 22.2v 6s LiPos, they looks fine. I am also looking maxamps 6s 8000mAh pacs, but I dont know witch LiPos I buy. Maxamps make more weight and I am not sure how fine my E-Revo go with them, so I am looking DualSky 5000mAh 6s LiPos now. What you peoples say, which LiPos are better for my E-Revo ? I think DualSkys .
