My MGM12018
gyn77
My MGM12018 - 10.24.2007, 02:52 PM
Hallo everybody,
I have programmed my MGM12018 choosing forward / backward mode and all seems ok.
When I run my model, if I go in FULL forward and then I reverse the stick, the motor brakes ok and if I put again the stick in backward the model goes in reverse.
But if I don't go in FULL FORWARD when I run, reversing the stick in backward the motor goes in reverse directly without braking before and this is not good!
I don't understanding if MGM works with this bad mode of reversing (so I'll must set the one way mode) or my esc has a problem.
Can anyone help me?
bdebde
That's All Folks!
bdebde's Avatar
10.24.2007, 03:13 PM
What software version is it? I know the earlier versions had more problems than the current version (still not perfect).
gyn77
10.24.2007, 03:35 PM
My ESC version is 3.11 and controller version is 1.2.6.
Finnster
KillaHurtz
Finnster's Avatar
10.24.2007, 04:14 PM
Yes, this is the stupid thing w/ MGMs/ They are otherwise great, but do not have a reverse lockout when travelling forward. If you double pump the brakes it will go into reverse generally people put them into fwd only. It would eb really nice if they updated this.
crazyjr
crazyjr's Avatar
10.24.2007, 04:38 PM
This is the 16018 not 12018 right?
Anyways, i had a similar problem with mine, but it would brake fine till i was at about 5 MPH then it might trip reverse, its a quirk of the esc design. If you don't need reverse, just set it to forweward/ brake and you will be fine
edit; I just checked my instructions and saw there is a 12018, sorry
bdebde
That's All Folks!
bdebde's Avatar
10.24.2007, 10:09 PM
I only have the problem of going into reverse at low speeds, like crazyjr. At high speeds I can hit the brake several times no problem.
gyn77
10.25.2007, 02:26 AM
This is not good!
I am a little disappointed for this with MGM.
I bought MGM 12018 to run my savage or my buggy at 6s lipo, but I would the backward mode too.
If I let the forward / backward mode, could I damage the esc, the motor and/or model trasmission?
MetalMan
MetalMan's Avatar
10.26.2007, 12:26 AM
MGMs have ALWAYS had this problem... The only way to get rid of it is to disable reverse. That's not always such a bad thing, though (IMO).
With such high power reverse like that, it's definitely possible to damage drivetrain on the buggy/truck, and I could imagine it being possible to also fry the ESC like this.
