pro-line Velocity rims with bandlands
ncalenda
Need for Speed
ncalenda's Avatar
pro-line Velocity rims with bandlands - 10.26.2007, 11:10 PM
I got the Velocity pro-line rims and I noticed that on the inside (or back side) of the rim there are 2 options were you can glue the tires. If you use the inner part the tire is more narrow and the outer will make the tire wider.
I plan to run on a track with gravel that is not too had packed, so it is loose. Then, I may also run in sand.
I have the pro-line bandlands. I have not used them yet, but I like the tire, can't wait to try them out.
What would you recommend, and what are the pros and cons with the inner vs the outer?
Ideally we will race around the track, not official but for fun.
Thanks!
  Send a message via AIM to ncalenda
